[postgis-users] Compile Problem with postgis
Oli Young
oli at katalyst.com.au
Thu Aug 26 06:05:40 PDT 2004
I'm trying to install postgis-0.7.5 on a Debian (sarge) box, with
postgresql-7.4.3 installed with apt-get.
I've followed the instructions as here --
http://edseek.com/archives/2004/03/31/installing-postgis-on-debian-
gnulinux/ -- and everything seemed okay until i've attempted to 'make'
postgis. Output as follows
[root at mojave][/usr/src/postgresql-7.4.3/build-tree/postgresql-7.4.3/
contrib/postgis-0.7.5][0]: make
i386-linux-gcc -DCHECK_RLIMIT_NOFILE -fno-strict-aliasing -g -Wall
-Wmissing-prototypes -Wmissing-declarations -pipe -fPIC -g -I.
-I../../src/include -D_GNU_SOURCE -I/usr/include/tcl8.4 -DFRONTEND
-DSYSCONFDIR='"/usr/etc/postgresql"' -DUSE_VERSION=73 -c -o
postgis_estimate.o postgis_estimate.c
postgis_estimate.c: In function `get_restriction_var':
postgis_estimate.c:543: warning: assignment from incompatible pointer
type
postgis_estimate.c:545: warning: assignment from incompatible pointer
type
postgis_estimate.c: In function `genericcostestimate2':
postgis_estimate.c:752: error: structure has no member named `elem'
postgis_estimate.c:752: error: too few arguments to function
`clauselist_selectivity'
postgis_estimate.c:810: warning: passing arg 1 of `cost_qual_eval' from
incompatible pointer type
postgis_estimate.c:810: error: too few arguments to function
`cost_qual_eval'
postgis_estimate.c:810: error: void value not ignored as it ought to be
make: *** [postgis_estimate.o] Error 1
Any ideas ?
Thanks in advance
Oli
