[postgis-users] PostGIS Manual: Indexes and PostgreSQL 7.5
Steffen Macke
sdteffen at web.de
Mon Aug 30 23:01:09 PDT 2004
I'm confused by contradicting information in the PostGIS manual
(Section on Indexes)
"-- This is only needed for PostgreSQL 75 installations
SELECT UPDATE_GEOMETRY_STATS([table_name], [column_name]);"
and
"For PostgreSQL 75 installations this is done by
running "update_geometry_stats([table_name, column_name])"
(compute distribution) and "VACUUM ANALYZE [table_name]
[column_name]" (compute number of values)."
but
" Starting with
PostgreSQL 75 running "VACUUM ANALYZE" will do both operations."
Did an automatic replacement of version numbers go wrong?
Steffen
