[postgis-users] spatial update SQL
Wood Brent
pcreso at pcreso.com
Tue Aug 31 16:21:21 PDT 2004
--- David Blasby <dblasby at gmail.com> wrote:
> Ethan,
> update celltable set celltable.value =
> SELECT avg( point.value ) from point where celltable.the_geom &&
> point.the_geom and contains(celltable.the_geom,point.the_geom)
> This query is going to do the same thing as your program. Do an
> "explain" and you'll see the query plan is very similiar to what your
> program does (i.e. does a sequential scan of the cell table, executing
> the sub-query for each row).
> (If there's no points inside a cell, avg() will return NULL)
In my case the cells are all rectangular & adjacent so contains is not
necessary, the && operator uses the bounding box which is the same extent as my
feature. I assume this will speed things up.
What I can't see is how the subquery "knows" which cell to work on. I looked at
this approach & figured that the subquery was not limited to just the single
cell to be updated. Is my understanding wrong & the subquery will only use the
current cell from the parent query automagically?
Brent Wood
