[postgis-users] java and postgis: your suggestions and ideas
Seamus Thomas Carroll
carrolls at cpsc.ucalgary.ca
Tue Feb 3 14:32:08 PST 2004
Apparently i left my brain at home today. the postgis jump driver being
versioned 1.0 caused me to think that it was for jump1.0.
Seamus
On Tue, 3 Feb 2004, Seamus Thomas Carroll wrote:
> I have looked into using JUMP but from what I last read JUMP1.1 does not
> support postgis. Has this changed? If there is a postgis driver for
> jump1.1 that has not been officialy released where can I get it.
> Regards to GISToolkit:
> Would an accuracy problem cause some layers to appear correctly while
> causing another layer to dissappear? If this is so I will look into the
> code and follow your advice.
> Seamus
> > >For the past two weeks I have been working with the GISToolKitEditor
> > >changing it to suite my needs. I did some testing today where I add a few
> > >layers from the database and zoom in. As I zoom in closer a specific
> > >layer begins to distort or disappear. It is not a postgis issue because i
> > It really just sounds like you are running into accuracy issues, The
> > conversion from double coordinates maintained by Postgis to the Java
> > Shape which use float are probably to blame. Try and take manual
> > control of the zoom process and make sure doubles are used for as long
> > as possible.
> > >2) I may be forced to change java libraries so can anyone recommend a
> > >different java library that I can use as a stand alone tool?
> > JUMP Exists, has a Postgis loader. It is GPL, runs as a stand alone tool.
> > GeoTools2 exists has a Postgis data store and some renderers, it is not
> > a stand alone tool. But is LGPL.
> > >I have other suggestions and question but I have not recieved a response
> > >to my first question on the GISToolkit Sourceforge website.
> > Cheers,
> > Jody, Refractions Research
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
