[postgis-users] Redhat 9 Help
arun at activeengineer.com arun at activeengineer.com
Wed Feb 4 06:27:06 PST 2004
Jeremy,
I read your post with interest since I am having similar problem. I installed
postgresql-7.4.1 from source. Then I tried to install postgis from contrib
directory of postgresql. I get the same error ( ERROR: current transaction is
aborted, queries ignored until end of transaction"  ), whole bunch of them when
installing postgis.sql.
I am using Redhat 9.
I am exploring as to what is causing the error but have not found any clue yet.
Arun
Quoting Jeremy Palmer <jpalmer at paradise.net.nz>:
> Hi,
> I'm new to the world of linux and redhat and I'm having great trouble
> installing postgis with geos and proj support. When a do a standard install
> following the instructions i.e
> configure, make, make install - for geos and proj; configure
> --enable-multibyte --with-CXX --prefix=/usr --sysconfdir=/etc
> --docdir=/usr/doc/postgresql-$version
> make - for postgresql 7.4.1 and;
> make install - for postgis
> I get problems with the creation of a postgis database. For some reason the
> system cannot find postgis.sql or spatial_ref_sys.sql it had to explicitly
> enter the path to the contrib folder and when I ran the postgis.sql on the
> database it came up lots of - "ERROR: current transaction is aborted,
> Initially I thought the main problem was that redhat by default installs
> postgresql library files to /var/lib/pgsql and support files to
> /var/share/pgsql directories, while geos and proj seems set up on configure
> to install into /usr/local/postgres etc.
> However when I tried changing the configure options for the make and install
> of geos and proj i.e.
> configure --mandir=/usr/share/man --bindir=/usr/bin --libdir=/usr/lib/pgsql
> --libexecdir=/usr/lib/pgsql --includedir=/usr/include --infodir=/usr/share
> --datadir=/usr/share
> make postgis then starting complaining about postgis_geos_wapper and
> postgis_proj_wapper failing. Do I now have to change the configure options
> for the make of postgresql
> If someone has guide or could help me out with installing Postgis on redhat
> it would be greatly appreciated.
> Thanks Jeremy Palmer
> postgis-users mailing list
