[postgis-users] Homework for RPM Users
Christoph Spoerri
spoerri at duke.edu
Wed Feb 4 06:57:21 PST 2004
Hi Paul,
I have a mandrake 9.1 and 9.2 system. I'll try to create RPMs for both of
them.
Christoph
On Wednesday 04 February 2004 01:26 am, Paul Ramsey wrote:
> Hi RPM'ers.
> I have finished compiling a complete set of SRPM packages for postgis,
> mapserver, and all other required open source libraries. Now, I need
> you, the fine users of postgis, to compile them for me on different
> platforms.
> If someone has a default install of Fedora 1, they should compile
> flawlessly (omit the curl package, you already have that).
> For Red Hat 9, again, everything should be hunky dory, but you'll have
> to do the curl package, as the RH9 default is not a high enough version
> for mapserver.
> For older distros, things will probably get harder, but might still
> work OK. Red Hat 7.3 is probably the most important, since it was very
> widespread.
> For Fedora, RH9, building SRPMS is really easy.
> - Make sure you have rpm-devel installed already.
> - rpm -Uvh sourcepackage.src.rpm
> - cd /usr/src/redhat/SPECS
> - rpmbuild -bb sourcepackage.spec
> - find your new RPM in /usr/src/redhat/RPMS/i386
> - the recommended build order is curl, geos, proj, gdal, postgresql,
> mapserver
> - when you have built RPMs and have tested them, drop me a line so I
> can put them online for others to download
> For my next trick, I will bundle some demo data and interfaces with the
> mapserver build so that it just "runs" out of the box.
> Paul Ramsey
> Refractions Research
> Email: pramsey at refractions.net
> Phone: (250) 885-0632
> postgis-users mailing list
