[postgis-users] some questions about PostGIS internals
Paul Ramsey
pramsey at refractions.net
Wed Feb 4 07:53:13 PST 2004
On Wednesday, February 4, 2004, at 02:57 AM, bartvde at xs4all.nl wrote:
> 1) somewhere I read that the GiST indexes in PostgreSQL could only deal
> with 1 concurrent user. Is this correct? And did PostGIS make a new
> implementation of GiST differing from the PostgreSQL one to overcome
> this?
> How does PostGIS make sure it gets used in the Explain Plan etc. from
> PostgreSQL?
This is a similar question to 3. PostGIS spatial indexes are build on
PostgreSQL GiST indexes. PostgreSQL GiST indexes support table-level
locking only. So if you have two nearly simultaneous updates/inserts,
one will block until the other is finished. It just means that spatial
tables will not scale as well as non-spatial tables under concurrent
update/insert load.
It is worth noting that the GiST maintainers are currently working on
more atomic locking code, which may end up in the 7.5 release. If you
have an enterprise need for that functionality, you should consider
funding them, to ensure they get it done and soon.
> 2) is the geometry column in PostGIS a real database column? Does it
> make
> use of the Spatial types in PostgreSQL?
What does this mean, "real"? It is a real type, like any other
PostgreSQL type. PostgreSQL supports full custom types and functions,
so an add-on like PostGIS can add functionality to the system. Types
and functions from PostGIS are as real as the built in types and
functions.
No, we do not use the PostgreSQL spatial types. You can read some of
the early justifications in the early postings on the PostGIS list.
Basically, their semantics were not rich enough to support GIS (no
holes, no aggregates).
> 3) is there only table level locking or also row level locking (like it
> says in the TODO list)? Or did this already get implemented in the
> database because of the recent Geoserver development?
As above, the locking for tables with a spatial index is table level.
If there is no spatial index, then the locking could be row-level.
Locking limitations really only slow you down if your have concurrent
inserts/updates.
GeoServer development is different, because GeoServer WFS locking
semantics are slightly different from DBMS semantics. GeoServer
supports locking of rows, for long transactions, using a special
locking table. This does not improve true concurrency at all, because
the underlying tables and locks are still PostgreSQL, so they still
have the same limitations. It does allow user A to edit rows 9-10 while
user B has rows 15-16 locked, because the locking mechanism is not the
internal database locks. The GeoServer locking is "concurrent" in that
you can have write operations on some rows while others are locked. It
is not "concurrent" in that truly simultaneous operations (simultaneous
in the time axis) will block one operation until the other clears, due
to the PostgreSQL backend locking. Clear as mud? It should be. It would
take about a 20 minute presentation to explain the semantics of this to
someone without the background knowledge.
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
