[postgis-users] distance function only supports 2d?
David Blasby
dblasby at refractions.net
Wed Feb 4 14:37:56 PST 2004
We could probably construct a distance3d() function that would work on
point and lines, but it will be extreamly difficult to do correctly for
polygons.
We'll need the following functions:
a) 3d point to 3d point distance (easy)
b) 3d point to 3d line segement distance (not too difficult)
c) 3d line to 3d line distance (hopefuly we can find this on the internet)
Here's the code for (b) and (c) in the 2d case. The 3d case will be
much much more difficult:
//distance from p to line A->B
double distance_pt_seg(POINT3D *p, POINT3D *A, POINT3D *B)
double r,s;
//if start==end, then use pt distance
if ( ( A->x == B->x) && (A->y == B->y) )
return distance_pt_pt(p,A);
//otherwise, we use comp.graphics.algorithms Frequently Asked Questions
method
/*(1) AC dot AB
r = ---------
||AB||^2
r has the following meaning:
r=0 P = A
r=1 P = B
r<0 P is on the backward extension of AB
r>1 P is on the forward extension of AB
0<r<1 P is interior to AB
r = ( (p->x-A->x) * (B->x-A->x) + (p->y-A->y) * (B->y-A->y) )/(
(B->x-A->x)*(B->x-A->x) +(B->y-A->y)*(B->y-A->y) );
if (r<0)
return (distance_pt_pt(p,A));
if (r>1)
return(distance_pt_pt(p,B));
/*(2)
(Ay-Cy)(Bx-Ax)-(Ax-Cx)(By-Ay)
s = -----------------------------
L^2
Then the distance from C to P = |s|*L.
s = ((A->y-p->y)*(B->x-A->x)- (A->x-p->x)*(B->y-A->y) )/
((B->x-A->x)*(B->x-A->x) +(B->y-A->y)*(B->y-A->y) );
return abs(s) * sqrt(((B->x-A->x)*(B->x-A->x) +(B->y-A->y)*(B->y-A->y) ));
// find the distance from AB to CD
double distance_seg_seg(POINT3D *A, POINT3D *B, POINT3D *C, POINT3D *D)
double s_top, s_bot,s;
double r_top, r_bot,r;
//printf("seg_seg [%g,%g]->[%g,%g] by [%g,%g]->[%g,%g]
\n",A->x,A->y,B->x,B->y, C->x,C->y, D->x, D->y);
//A and B are the same point
return distance_pt_seg(A,C,D);
//U and V are the same point
if ( ( C->x == D->x) && (C->y == D->y) )
return distance_pt_seg(D,A,B);
// AB and CD are line segments
/* from comp.graphics.algo
Solving the above for r and s yields
(Ay-Cy)(Dx-Cx)-(Ax-Cx)(Dy-Cy)
r = ----------------------------- (eqn 1)
(Bx-Ax)(Dy-Cy)-(By-Ay)(Dx-Cx)
s = ----------------------------- (eqn 2)
Let P be the position vector of the intersection point, then
P=A+r(B-A) or
Px=Ax+r(Bx-Ax)
Py=Ay+r(By-Ay)
By examining the values of r & s, you can also determine some other
limiting conditions:
If 0<=r<=1 & 0<=s<=1, intersection exists
r<0 or r>1 or s<0 or s>1 line segments do not intersect
If the denominator in eqn 1 is zero, AB & CD are parallel
If the numerator in eqn 1 is also zero, AB & CD are collinear.
r_top = (A->y-C->y)*(D->x-C->x) - (A->x-C->x)*(D->y-C->y) ;
r_bot = (B->x-A->x)*(D->y-C->y) - (B->y-A->y)*(D->x-C->x) ;
s_top = (A->y-C->y)*(B->x-A->x) - (A->x-C->x)*(B->y-A->y);
s_bot = (B->x-A->x)*(D->y-C->y) - (B->y-A->y)*(D->x-C->x);
if ( (r_bot==0) || (s_bot == 0) )
return (
min(distance_pt_seg(A,C,D),
min(distance_pt_seg(B,C,D),
min(distance_pt_seg(C,A,B),
distance_pt_seg(D,A,B) ) ) )
s = s_top/s_bot;
r= r_top/r_bot;
if ((r<0) || (r>1) || (s<0) || (s>1) )
//no intersection
return (
else
return -0; //intersection exists
