[postgis-users] Intersection problems
manuel gimond
gimond at hotmail.com
Wed Feb 4 17:29:45 PST 2004
I want to intersect a shapefile (stored in PGSQL as a geom table called
"layer")
and save the output to a separate table called "tmptable" in the same
database.
The shapefile was loaded in the database using PGSQL with the shp2psql
loader. I have successfully queried the table "layer" using Mapserver. The
script I have so far is as follows:
(FYI The variable $Ipolygon points to a string of coordinate values... this
SQL statement is embedded in a PERL script)
======================== start of SQL statement
CREATE TABLE public.tmptable (gid serial not null,
code integer,
desc character varying,
the_geom public.geometry,
CONSTRAINT tmptable_key PRIMARY KEY (gid),
CONSTRAINT "\$1" CHECK (srid(the_geom) = -1),
CONSTRAINT "\$2" CHECK
(geometrytype(the_geom) =
'MULTIPOLYGON'::text OR the_geom IS
NULL)
) with OIDS;
INSERT INTO tmptable (code,desc,the_geom)
SELECT lc.code,lc.desc,lc.the_geom from
(SELECT layer.gid as gid,
GeometryFromText(intersection(layer.the_geom,'POLYGON(($Ipolygon))'),-1) as
the_geom,
layer.code as code,
layer.desc as desc
from layer ) AS lc where (npoints(lc.the_geom) >1) ;
CREATE INDEX tmptable_index ON tmptable USING GIST(the_geom);
CREATE INDEX tmptable_oid ON tmptable ( oid );
======================= END of SQL Statement ===============================
I have 2 problems:
1) The intersection routine tries to populate the new table "tmptable" with
both
POLYGON and MULTIPOLYGON geometries even though the table "layer" has only
MUTLIPOLYGON geometires.
2) If I add the constraint " AND (geometrytype(the_geom) = 'MULTIPOLYGON')"
in the SELECT statement to temporarely bypass the problem
previously described, I get the following error message in the log file when
attempting to query the table "tmptable" from a Mapserver mapfile:
ERROR: find_srid() - couldnt find the corresponding SRID - is the geometry
registered in the GEOMETRY_COLUMNS table? Is there an uppercase/lowercase
missmatch?
Additional info: I am able to perform certain geometric functions on the
newly created "tmptable" such as AREA(geometry), and when I do a SELECT *
FROM tmptable I see both consitent GID
and THE_GEOM data.
Manny
_________________________________________________________________
Find high-speed net deals comparison-shop your local providers here.
https://broadband.msn.com
