[postgis-users] upgraded distance-on-ellipse calculations
David Blasby
dblasby at refractions.net
Thu Feb 5 12:46:58 PST 2004
I tested and modified the distance-on-ellipse calculations (in
postgis_proj.c). This affects the length_ellipse(linestring),
length3d_ellipse(linestring), and distance_ellipse(point,point) functions.
I tested it on 9 million point-to-point calculations and compared it to
the PROJ4 'geod' function. They agreed to about 1mm accuracy in all but
two case (3.5mm difference).
I also noticed that both the postgis method (orginally done by Dave Skea
- see code) and the PROJ4 method break down when the actual distance is
very small (<10cm). In order to handle this case, I added code that
looks at the curvature of the earth at one of the points. It works very
well (see complete description for the distance_sphere_method()) in this
case.
Currently, its setup to first try the accurate method. If this fails,
then it tries the curvature method.
dave
ps. The curvature method is about 20* quicker than the more accurate
method. 99.999% of the time the curvature method is within 0.1% of the
PROJ4/Skea method.
