[postgis-users] bug in bbox containment operators
Greg Janée
gjanee at alexandria.ucsb.edu
Fri Feb 6 08:38:15 PST 2004
The bounding box containment operators (@, ~) give spurious results.
I'm not sure if this is a PostGIS bug or a bug in PostgreSQL itself.
PostgreSQL 7.4, PostGIS 0.8.1, Solaris 8. Thanks, -Greg
gazsearch2=# select * from i_feature_footprint where footprint @
GeometryFromText('POLYGON((-120 30,-119 30,-119 31,-120 31,-120
30))',54001);
feature_id | footprint
3328 | SRID=54001;POLYGON((-180 -56,-180 85,180 85,180 -56,-180
-56))
125 | SRID=54001;POLYGON((-180 23.2099990844727,-180 71,180
71,180 23.2099990844727,-180 23.2099990844727))
156 | SRID=54001;POLYGON((-177.100006103516
13.710000038147,-177.100006103516 76.629997253418,-61.4799995422363
76.629997253418,-61.4799995422363 13.710000038147,-177.100006103516
13.710000038147))
6225435 | SRID=54001;POLYGON((-119.378890991211
28.6783294677734,-119.378890991211 38.6619415283203,-119.36222076416
38.6619415283203,-119.36222076416 28.6783294677734,-119.378890991211
28.6783294677734))
(4 rows)
Writing the query the other way around, i.e.,
30))',54001) ~ footprint;
gives the exact same results. Here's the table:
gazsearch2=# \d i_feature_footprint
Table "public.i_feature_footprint"
Column | Type | Modifiers
feature_id | integer | not null
footprint | geometry |
Indexes:
"i_feature_footprint_pkey" primary key, btree (feature_id)
"gis_index_footprint" gist (footprint)
Check constraints:
"$1" CHECK (srid(footprint) = 54001)
