[postgis-users] problem with multilinestring
Vladimir Guzmán
vguzman at maintask.com
Sat Feb 7 15:33:47 PST 2004
Hello.
I've got a table named 'arcos', with a MULTILINESTRING geometry named
'the_geom'.
I need to get the elements that starts or ends at a certain point.
If I query the database with "SELECT the_geom FROM arcos WHERE id=51892;"
I get:
the_geom
SRID=1;MULTILINESTRING((-74.1835602497749
4.62941345152032,-74.1837889284997 4.62928942801709,-74.1840390840234
4.62917486837267))
(1 row)
With the query "SELECT startpoint(the_geom) FROM arcos WHERE id=51892;"
I get:
startpoint
SRID=1;POINT(-74.1835602497749 4.62941345152032)
(1 row)
But if I try the query: "SELECT id FROM arcos WHERE startpoint(the_geom)
~= geometryfromtext('POINT(-74.1835602497749 4.62941345152032)',1);"
I get no results:
id
(0 rows)
And the same problem if i try: "SELECT id FROM arcos WHERE
x(startpoint(the_geom))::float = -74.1835602497749;"
id
(0 rows)
But if instead I try:"SELECT id FROM arcos WHERE
x(startpoint(the_geom))::text = -74.1835602497749;"
I get:
id
51892
But, obviously, this query is very slow, and is not getting the
geographic capabilities from postgis.
Any ideas?
Thanks in advance,
Vladimir Ilich Guzmán R.
http://www.maintask.com
