[postgis-users] 0.8.1 postgis.sql execution failure
strk
strk at keybit.net
Thu Feb 12 02:36:38 PST 2004
I've changed ifdef/ifndef checks to if / if !
in postgis_fn.c and postgis_geos.c
Current CVS version should work with USE_GEOS=0 also.
--strk;
jlbaugh wrote:
> Did make clean and then REMOVED the USE_PROJ=0 and USE_GEOS=0 from the Makefile and rebuilt okfine.
> Installed ok.
> > ------------Original Message------------
> > > Hi,
> > > Installed postgis 0.8.1 into contrib subdirectory of postgresql-7.4.1 source tree.
> > > USE_PROJ=0, USE_GEOS=0 and USE_STATS=0 in the Makefile. Make and Make Install okfine.
> > > Upon execution of postgis.sql, see..
> > > could not find function "centroid" below.
> > It seems to be a missing 'make clean'.
> > The 'centroid' function is defined in both postgis_fn.c and postgis_geos.c
> > Preprocessor directives make one or the other exist (ifdef/ndef USE_GEOS)
> > so you should always have it defined. In your case it should be defined
> > in postgis_fn.c.
> > --strk;
> > > Thanks for any help you can provide.
> > > [postgres at HPPAV postgis-0.8.1]$
> > > /usr/local/pgsql/bin/createlang plpgsql VericomTechGIS
> > > /usr/local/pgsql/bin/psql -f postgis.sql -d
> > > VericomTechGIS
> > > BEGIN
> > > message
> > > PL/PgSQL is installed.
> > > (1 row)
> > > psql:postgis.sql:44: NOTICE: type "histogram2d" is
> > > not yet defined
> > > DETAIL: Creating a shell type definition.
> > > CREATE FUNCTION
> > > psql:postgis.sql:49: NOTICE: argument type
> > > histogram2d is only a shell
> > > CREATE FUNCTION
> > > CREATE TYPE
> > > psql:postgis.sql:65: NOTICE: type "box3d" is not yet
> > > defined
> > > CREATE FUNCTION
> > > psql:postgis.sql:70: NOTICE: argument type box3d is
> > > only a shell
> > > CREATE FUNCTION
> > > CREATE TYPE
> > > psql:postgis.sql:85: NOTICE: type "spheroid" is not
> > > yet defined
> > > CREATE FUNCTION
> > > psql:postgis.sql:90: NOTICE: argument type spheroid
> > > is only a shell
> > > CREATE FUNCTION
> > > CREATE TYPE
> > > psql:postgis.sql:105: NOTICE: type "wkb" is not yet
> > > defined
> > > CREATE FUNCTION
> > > psql:postgis.sql:110: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:115: NOTICE: return type wkb is only
> > > a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:124: NOTICE: type "chip" is not yet
> > > defined
> > > CREATE FUNCTION
> > > psql:postgis.sql:129: NOTICE: argument type chip is
> > > only a shell
> > > CREATE FUNCTION
> > > CREATE TYPE
> > > psql:postgis.sql:145: NOTICE: type "geometry" is not
> > > yet defined
> > > CREATE FUNCTION
> > > psql:postgis.sql:150: NOTICE: argument type geometry
> > > is only a shell
> > > CREATE FUNCTION
> > > CREATE TYPE
> > > CREATE FUNCTION
> > > psql:postgis.sql:260: NOTICE: CREATE TABLE / PRIMARY
> > > KEY will create implicit index "spatial_ref_sys_pkey"
> > > for table "spatial_ref_sys"
> > > CREATE TABLE
> > > psql:postgis.sql:280: NOTICE: CREATE TABLE / PRIMARY
> > > KEY will create implicit index "geometry_columns_pk"
> > > for table "geometry_columns"
> > > CREATE TABLE
> > > UPDATE 1
> > > UPDATE 1
> > > UPDATE 1
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > psql:postgis.sql:473: NOTICE: return type wkb is only
> > > a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:478: NOTICE: return type wkb is only
> > > a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:483: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:488: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:493: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:498: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:503: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:508: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:513: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:518: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:524: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:529: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:534: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:539: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:544: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:549: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:555: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:560: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:566: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:571: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:576: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:581: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:587: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:592: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:597: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:602: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:607: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:612: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:619: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > psql:postgis.sql:624: NOTICE: argument type wkb is
> > > only a shell
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > CREATE FUNCTION
> > > psql:postgis.sql:1004: ERROR: could not find function
> > > "centroid" in file
> > > "/usr/local/pgsql/lib/libpostgis.so.0.8"
> > > psql:postgis.sql:1009: ERROR: current transaction is
> > > aborted, commands ignored until end of transaction
> > > block
> > > psql:postgis.sql:1014: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1024: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1029: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1034: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1039: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1044: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1049: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1054: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1063: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1068: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1074: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1079: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1085: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1090: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1097: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1107: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1112: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1117: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1122: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1127: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1132: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1137: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1142: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1151: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1156: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1161: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1166: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1171: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1176: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1185: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1190: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1199: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1209: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1215: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1221: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1227: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1233: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1239: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1245: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1251: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1261: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1267: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1273: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1279: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1284: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1294: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1299: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1304: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1310: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1315: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1320: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1326: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1332: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1338: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1343: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1350: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1356: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1361: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1366: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1371: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1376: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1381: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1386: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1391: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1396: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1401: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1406: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1416: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1481: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1487: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1488: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1489: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1490: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1491: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1492: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1493: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1494: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1509: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1528: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1538: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1547: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1556: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1565: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1570: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1579: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1584: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1589: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1594: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1599: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1604: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1609: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1618: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1623: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1628: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1650: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1654: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1663: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1707: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1815: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1826: ERROR: current transaction is
> > > block
> > > psql:postgis.sql:1913: ERROR: current transaction is
> > > block
> > > COMMIT
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
