[postgis-users] Update geometry_columns!
David TECHER
davidtecher at yahoo.fr
Fri Feb 13 05:30:41 PST 2004
Hello
As I tell you in a mail I sent to you
if your table is not declared in geometry_columns
doesn't matter if you just add
as foo using unique gid using SRID=-1
in DATA. do
DATA "geom from unidade_federativa as foo using unique
gid using SRID=-1"
and try mapserver to see your image.
if you have change the name of your geometry_columns
table do
alter table <youroldtable> rename to geometry_columns
update
--- André Cruvinel Resende
<andrecruvinel at yahoo.com.br> a écrit : > Hello David
and everybody,
> Are you right, I've change the name of my tables.
> How can i update the namos on my geometry_columns
> table?
> Andre
> Ps.: Sorry by creating another topic.
> Hi
> I think it is because your table is not declared in
> your geometry_columns table. MapServer can't find
> your
> SRID in the geometry_columns
> Try :
> select * from geometry_columns
> and see if
> you find something like
> f_table_name f_geometry_column srid
> unidade_federativa geom ...
> So tell me.
> David
> <andrecruvinel at yahoo.com.br> a écrit : > Hi,
> > I'm using:
> > RedHat 9
> > mapserver-4.0.1
> > postgres-7.3.2
> > postgis-0-8-1
> > I load the geographic data using shp2pgsql.
> > When i try to load the layer "unidade_federativa",
> > the
> > postgres return this error.
> > msDrawMap(): Image handling error. Failed to draw
> > layer
> > named 'unidade_federativa'.
> > prep_DB(): Query error. Error executing POSTGIS
> > DECLARE
> > (the actual query) statement: 'DECLARE mycursor
> > BINARY
> > CURSOR FOR SELECT
asbinary(force_collection(force_2d(geom)),'NDR'),OID::text
> > from unidade_federativa WHERE geom &&
> > setSRID('BOX3D(-58.9171479166667
> > -30.9797,-47.6857979166667
> > -19.7447)'::BOX3D,
> > find_srid('','unidade_federativa','geom') )'
> > The layer definitions on my map file are:
> > LAYER
> > CONNECTIONTYPE postgis
> > NAME "unidade_federativa"
> > TYPE POLYGON
> > CONNECTION "user=usuario password=senha
> > dbname=sig_cartafrete host=localhost"
> > DATA "geom from unidade_federativa"
> > STATUS ON
> > CLASS
> > COLOR -1 -1 -1
> > OUTLINECOLOR 0 0 0
> > END
> > END
> > Any idea of what could be wrong?
> > []'s
> > Andre
______________________________________________________________________
> > Yahoo! GeoCities: 15MB de espaço grátis para criar
> > seu web site!
> > http://br.geocities.yahoo.com/
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
> seu web site!
Yahoo! Mail : votre e-mail personnel et gratuit qui vous suit partout !
Créez votre Yahoo! Mail sur http://fr.benefits.yahoo.com/
