[postgis-users] pg7.4.1 performance problem
Daryl Herzmann
akrherz at iastate.edu
Tue Feb 17 22:29:26 PST 2004
Hiya PostGISers,
I have a performance problem on a recently migrated 7.3.2 database to
7.4.1. Fully patched RH 8. PostGIS 0.8.1, GEOS 1
Here is my first query that looks good:
explain analyze
SELECT asbinary(force_collection(force_2d(geo)),'NDR'),oid::text from
(select
d.oid as oid, d.rainfall / 25.4 as rainfall,
h.the_geom as geo from
daily_rainfall_2003 d , hrap_polygons h
WHERE d.hrap_i = h.hrap_i and d.valid = '2003-11-25') as foo ;
QUERY PLAN
Merge Join (cost=2082.92..3259.71 rows=2627 width=252) (actual
time=13.800..13.809 rows=1 loops=1)
Merge Cond: ("outer".hrap_i = "inner".hrap_i)
-> Sort (cost=2082.92..2101.70 rows=7510 width=6) (actual
time=0.302..0.332 rows=66 loops=1)
Sort Key: d.hrap_i
-> Index Scan using daily_rainfall_valid_idx on
daily_rainfall_2003 d (cost=0.00..1599.48 rows=7510 width=6) (actual
time=0.047..0.210 rows=66 loops=1)
Index Cond: ("valid" = '2003-11-25'::date)
-> Index Scan using hrap_polygons_hrap_i_idx on hrap_polygons h
(cost=0.00..1073.16 rows=7988 width=252) (actual time=0.013..8.753
rows=5102 loops=1)
Total runtime: 13.931 ms
(8 rows)
Now we add in the bounding box constraint that mapserver generates and we
get
explain analyze
(select
WHERE geo &&
setSRID('BOX3D(159999.999983024 4424687.49997101,
760000.000004331 4875312.5)'::BOX3D, 26915 );
QUERY PLAN
Nested Loop (cost=0.00..2786.49 rows=1 width=252) (actual
time=1109.977..1778.253 rows=1 loops=1)
Join Filter: ("inner".hrap_i = "outer".hrap_i)
(cost=0.00..1093.13 rows=1 width=252) (actual time=0.053..23.555 rows=7988
loops=1)
Filter: (the_geom && 'SRID=26915;BOX3D(159999.999983024
4424687.49997101 0,760000.000004331 4875312.5 0)'::geometry)
-> Index Scan using daily_rainfall_valid_idx on daily_rainfall_2003 d
(cost=0.00..1599.48 rows=7510 width=6) (actual time=0.009..0.158 rows=66
loops=7988)
Total runtime: 1778.341 ms
Whoaaa, this isn't good. This is just a modest example. Queries on dates
with more data basically don't return (impatience on my part). Well,
before I ask the pgsql-performance folks, any thoughts from the PostGIS
side?
Thanks,
Daryl
* Daryl Herzmann (akrherz at iastate.edu)
* Program Assistant -- Iowa Environmental Mesonet
* http://mesonet.agron.iastate.edu
