[postgis-users] pg7.4.1 performance problem
David Blasby dblasby at refractions.net
Wed Feb 18 10:39:22 PST 2004
Tyler Mitchell wrote:
>  > Did you compile postgis with "USE_STATS=1"? Have you updated your
>  > stats tables
>  > recently by calling the correct function? It should be in the docs
> somewhere,
>  > or if not, then it's at least in Dave's head.
> DAVE - can you refresh our memories - what's the function.  What will
> this stats option do for me?
its:
select update_geometry_stats();
Make sure your column is in the geometry_columns table.
When you "select * from geometry_columns;" you should see a big
histogram2d in there.
Also, when you do an "EXPLAIN ANAYLSE ..." you should see the predicted
# of rows to be 'close to' the actual number of rows.
dave
