[postgis-users] postgis c or c++ parser
Wed Feb 18 13:43:33 PST 2004
Seamus Thomas Carroll wrote:
> Hi,
> Does a parser exist that turns the postgis data read from postgres into a
> data structure that can be easily used?
> IE. An array of doubles representing the points returned.  Something
> similiar in function to the java postgis library.
Seamus,
It isn't really a lightweight solution, but the OGR library can be used
for this purpose.  It will read PostGIS features and turn them into C++
objects from which you can get geometry bits, attribute values and so
forth.
  http://ogr.maptools.org/
Best regards,
