[postgis-users] Improving Performance
Ralph Mason
ralph.mason at telogis.com
Thu Feb 19 12:17:29 PST 2004
I think it wouldn't be to difficult to benchmark the bounding box being
floats / doubles / gone altogether. The optimum setting is likely to be
based on the actual machine it's running on. I wouldn't be surprised if
no bounding box was actually the fastest on a modern fast processor with
a good sized cache.
It seems the space savings could be significant ( probably 40% when you
consider also an extra 8 bytes in each point in the geometry). And with
Disk access followed by memory access being the main bottle necks
anything to reduce the volume of data has to have a beneficial effect on
performance.
I don't think it needs to lead to a proliferation of types. Just
another type geometry_2d or something like that. I am also in favor or
removing the projection, so that functions working with 2d geometrys
don't need to consider it.
It would be interesting to know for sure, but I suspect that most users
of postgis are using 2d geometries and all their data is in one
projection. Meaning that a faster smaller 2d type would probably make
up the bulk of the use, with the full geometry being used to massage
data into the smaller type.
Anyway I am keen to support any effort, with time and or a donation.
Ralph
David Blasby wrote:
> colin> We were wondering why a sample 200MB text file of 8
> colin> million points ballooned into over a gigabyte when
> Your text file is using about 26 bytes/point.
> WKB representation (in posgresql) would be 29 bytes/point.
> If you want, you can create this now with "CREATE TABLE myWKB AS
> SELECT asBinary(the_geom), ... FROM ...". Unfortunately there isnt
> much support wrapped around the WKB type at the momenet.
> The current postgis implementation is about 114 bytes/point (thats
> why you're seeing 5* larger size in postgresql).
> By taking the redundant info (56 bytes) out of the postgis type,
> it would be about 58 bytes.
> redunandant info: BVOL.zmin (8 bytes), BVOL.zmax (8 bytes),
> offsetX (8 bytes), offsetY (8 bytes), scale (8 bytes),
> convert the bounding box to float32s (16 bytes).
> ** I'm not sure if its a good idea to convert the bounding box to
> float32s. We might be able to remove the entire bounding box, but
> I'm not sure how that would affect performance.
> I'm a bit wary of using a bunch of different types for different
> "geometric things" in the database. There's a high cost associated
> with getting a type up and running, indexable, and convertable to and
> from the GEOMETRY type. Thats why I recommended a full WKB type since
> it can represent any geometry relatively efficiently. Because there
> already
> GEOMETRY <-> WKB functions, we can add all the geometric functions to
> the type automatically.
> dave
