[postgis-users] install postgis on windows
Tyler Mitchell TMitchell at lignum.com
Thu Feb 19 13:30:11 PST 2004
postgis-users-bounces at postgis.refractions.net wrote on 02/19/2004 11:58:13
AM:
> Hi,
> I want to install the Postgis software on Windows XP, and to do this
I´ve
> read the the Windows Postgis Installation Guide document, but in the set
up
> Postgis step, when I want to configure the PostgreSQL with the
"./configure"
> command, in order to configure the master makefile correctly, I obtain
the
> follow error message: "configure: error: no acceptable C compiler found
in
> $PATH".
Adolfo,
I assume you are using Cygwin on Windows to do the install.   You may want
to re-run Cygwin setup and make sure the "gcc" application is checked on
and installed.  That should help.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040219/1b5862ea/attachment.html>
