[postgis-users] (no subject)
jpalmer at paradise.net.nz jpalmer at paradise.net.nz
Sun Feb 22 13:19:44 PST 2004
Yes I installed postgres from the RPM's. But it still might be useful to
know how to do it both ways, with the source (with redhat's directory
structure) and the rpms.
Thanks
-----Original Message-----
From: Darren Houston [mailto:dhouston at beyondcompliance.ca]
Sent: Sunday, 22 February 2004 11:26 p.m.
To: PostGIS Users Discussion
Cc: jpalmer at paradise.net.nz
Subject: Re: [postgis-users] Help on Postgresql 7.4.1 install with postgis
0.81
Hello Jeremy,
Am I correct in assuming you installed PostgreSQL 7.4.1 from RPMs?
You can install PostGIS with an RPM installed PostgreSQL, but it takes a
little
ingenuity. If you installed PostgreSQL from source, then PostGIS is a snap.
E-mail back telling how PostgreSQL was installed and I'll help you out.
Jeremy Palmer <jpalmer at paradise.net.nz> said:
> Hi,
> I'm new to the world of postgis and postgreSQL. Up until now I have used
the
> redhat 9.0 rpms for the install of postgis, geos and proj. However the
rpms
> have only been compiled for postgres 7.3.1 and I wanted to use the latest
> version of 7.4.1. I have downloaded and installed all of the sources. My
> question is that with postgresql, postgis, proj and geos it seems the
> configure scripts by default install the files to /usr/local/lib and
> /usr/local/pgsql, and as far as I can tell I think under the redhat the
> files should be going to /usr/bin and /usr/bin and postgresql data
directory
> should be in the /var/lib/pgsql/? Could someone please show me how to
> configure postgresql, postgis, geos and proj scripts so that the "make
> install" of the sources will install into the correct directories. The
> configure options are a little confusing to me!
> Thank you very much for your time.
> Jeremy
> postgis-users mailing list
Darren Houston
