[postgis-users] Help on Postgresql 7.4.1 install with postgis 0.81
Darren Houston dhouston at beyondcompliance.ca
Sun Feb 22 13:31:51 PST 2004
I have not seen any PostgreSQL 7.4.1 RPMs for RH9 yet. Many people have said the
RHEL 3 RPMs work fine on RH9.
To see the configure options used for an RPM install, execute pg_config
--configure
If you want to compile the JDBC drivers and tools for PostgreSQL with the
--with-java configure option, you will need Ant installed on your system and
included in your PATH. See Ant at http://ant.apache.org/
For now, let us get PostGIS working on your system with the RPM install. I will
write up a short document telling how to do this. In the meantime, while you
wait for the document, go and download the source postgresql-7.4.1.tar.gz or
.bz2, PostGIS 0.8.1 or CVS, GEOS from CVS, and Proj-4.4.7.
Jeremy Palmer <jpalmer at paradise.net.nz> said:
>Yes I installed postgres from the RPM's. But it still might be useful to
>know how to do it both ways, with the source (with redhat's directory
>structure) and the rpms.
>Thanks
> -----Original Message-----
> From: Darren Houston [mailto:dhouston at beyondcompliance.ca]
> Sent: Sunday, 22 February 2004 11:26 p.m.
> To: PostGIS Users Discussion
> Cc: jpalmer at paradise.net.nz
> Subject: Re: [postgis-users] Help on Postgresql 7.4.1 install with postgis
> 0.81
> Hello Jeremy,
> Am I correct in assuming you installed PostgreSQL 7.4.1 from RPMs?
> You can install PostGIS with an RPM installed PostgreSQL, but it takes a
> little
> ingenuity. If you installed PostgreSQL from source, then PostGIS is a snap.
> E-mail back telling how PostgreSQL was installed and I'll help you out.
> > Hi,
> > I'm new to the world of postgis and postgreSQL. Up until now I have used
> the
> > redhat 9.0 rpms for the install of postgis, geos and proj. However the
> rpms
> > have only been compiled for postgres 7.3.1 and I wanted to use the latest
> > version of 7.4.1. I have downloaded and installed all of the sources. My
> > question is that with postgresql, postgis, proj and geos it seems the
> > configure scripts by default install the files to /usr/local/lib and
> > /usr/local/pgsql, and as far as I can tell I think under the redhat the
> > files should be going to /usr/bin and /usr/bin and postgresql data
> directory
> > should be in the /var/lib/pgsql/? Could someone please show me how to
> > configure postgresql, postgis, geos and proj scripts so that the "make
> > install" of the sources will install into the correct directories. The
> > configure options are a little confusing to me!
> > Thank you very much for your time.
> > Jeremy
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Darren Houston
Darren Houston
