[postgis-users] strange beahviuors by GEOS
James S reid
james.reid at ed.ac.uk
Tue Feb 24 04:25:16 PST 2004
thanks for that - Ive rebuilt with 0.8.0 and it seems to load and unload
faithfully - I still have the problem with the within() operator though -
arcview reports more polys on a contains select by theme than I can get with
the within() operator?
james
----- Original Message -----
From: "Darren Houston" <dhouston at beyondcompliance.ca>
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Cc: <james.reid at ed.ac.uk>
Sent: Tuesday, February 24, 2004 9:42 AM
Subject: Re: [postgis-users] strange beahviuors by GEOS
> Hello James,
> Well, I loaded and dumped your data. This is what I got.
> The loader works fine (PostGIS CVS from February 22, 2004).
> The dumper does not work, gives the mangled polygons just like nuts2
(PostGIS
> The dumper from PostGIS 0.7.5 works fine, gives a polygon like
nuts2_scotland.
> Therefore, I would say there is a bug in the current PostGIS dumper. You
can
> download an earlier version of pgsql2shp, or download PgArc which allows
you to
> connect to and dump shapes from PostgreSQL into ArcView 8.X. See
> http://sourceforge.net/projects/pgarc/
> Hope this helps,
> James S reid <james.reid at ed.ac.uk> said:
> > ------=_NextPart_001_0DE5_01C3FAB5.4DE25910
> > Content-Type: text/plain;
> > charset="iso-8859-1"
> > Content-Transfer-Encoding: quoted-printable
> > hi again - thanks for replying - I had a thought overnight and decided =
> > to check the input data by dumping the loaded shapefiles and its heer =
> > the problem lies - the correct number of recorsd are reported in teh =
> > tables and by the loade/dumper but taking the orignal shapefile, loading
> > it then dumping it to a new shapefile reveals that the .shp itself is =
> > funny and causes the generic 'segmentation violation' in av3.1 and has =
> > lots of offshoots and strange polys in AV8. ive attached a zipfielof teh
> > original shapefile and the dumped one (nuts2.shp).
> > I guess its to do with being a multipolygon with holes and islands but =
> > Im not sure how to proceed to get the data loaded properly ???
> > cheers
> > james
> > ----- Original Message -----=20
> > From: Tyler Mitchell=20
> > To: PostGIS Users Discussion=20
> > Sent: Monday, February 23, 2004 6:27 PM
> > > hi - Im testing a polygon in polygon selection using the within() =
> > operator
> > > on two tables and have come across some odd return sets. =
> > essentially, I can
> > > confirm the 'proper' results in arcview (booh hiss) but postgis =
> > (using geos)
> > > returns 1 less poly for no reason that i can see!
> > Hi James,=20
> > Could you show us the SQL you are using? Ideally a small screenshot =
> > showing the map data would be nice too.
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > Content-Type: text/html;
> > <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
> > <HTML><HEAD>
> > <META http-equiv=3DContent-Type content=3D"text/html; =
> > charset=3Diso-8859-1">
> > <META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR>
> > <STYLE></STYLE>
> > </HEAD>
> > <BODY bgColor=3D#ffffff>
> > <DIV><FONT face=3DArial size=3D2>hi again - thanks for replying - I had
> > a thought=20
> > overnight and decided to check the input data by dumping the loaded =
> > shapefiles=20
> > and its heer the problem lies - the correct number of recorsd are =
> > reported in=20
> > teh tables and by the loade/dumper but taking the orignal shapefile, =
> > loading it=20
> > then dumping it to a new shapefile reveals that the .shp itself is funny
> > and=20
> > causes the generic 'segmentation violation' in av3.1 and has lots of =
> > offshoots=20
> > and strange polys in AV8. ive attached a zipfielof teh original =
> > shapefile and=20
> > the dumped one (nuts2.shp).</FONT></DIV>
> > <DIV><FONT face=3DArial size=3D2></FONT> </DIV>
> > <DIV><FONT face=3DArial size=3D2>I guess its to do with being a =
> > multipolygon with=20
> > holes and islands but Im not sure how to proceed to get the data loaded
> > properly=20
> > ???</FONT></DIV>
> > <DIV><FONT face=3DArial size=3D2>cheers</FONT></DIV>
> > <DIV><FONT face=3DArial size=3D2>james</FONT></DIV>
> > <BLOCKQUOTE=20
> > style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
> > BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
> > <DIV style=3D"FONT: 10pt arial">----- Original Message ----- </DIV>
> > <DIV=20
> > style=3D"BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: =
> > black"><B>From:</B>=20
> > <A title=3DTMitchell at lignum.com =
> > href=3D"mailto:TMitchell at lignum.com">Tyler=20
> > Mitchell</A> </DIV>
> > <DIV style=3D"FONT: 10pt arial"><B>To:</B> <A=20
> > title=3Dpostgis-users at postgis.refractions.net=20
> > href=3D"mailto:postgis-users at postgis.refractions.net">PostGIS Users=20
> > Discussion</A> </DIV>
> > <DIV style=3D"FONT: 10pt arial"><B>Sent:</B> Monday, February 23, 2004
> > 6:27=20
> > PM</DIV>
> > <DIV style=3D"FONT: 10pt arial"><B>Subject:</B> Re: [postgis-users] =
> > strange=20
> > beahviuors by GEOS</DIV>
> > <DIV><BR></DIV><BR><FONT size=3D2><TT>> hi - Im testing a polygon =
> > in polygon=20
> > selection using the within() operator<BR>> on two tables and have =
> > come=20
> > across some odd return sets. essentially, I can<BR>> confirm the =
> > 'proper'=20
> > results in arcview (booh hiss) but postgis (using geos)<BR>> =
> > returns 1 less=20
> > poly for no reason that i can see!<BR></TT></FONT><BR><FONT =
> > size=3D2><TT>Hi=20
> > James,</TT></FONT> <BR><FONT size=3D2><TT>Could you show us the SQL =
> > you are=20
> > using? Ideally a small screenshot showing the map data would be =
> > nice=20
> > too.</TT></FONT>
> > <P>
> > <HR>
<P></P>_______________________________________________<BR>postgis-users=20
> > mailing=20
list<BR>postgis-users at postgis.refractions.net<BR>http://postgis.refractio=
> > ns.net/mailman/listinfo/postgis-users<BR></BLOCKQUOTE></BODY></HTML>
> > ------=_NextPart_001_0DE5_01C3FAB5.4DE25910--
> Darren Houston
