[postgis-users] geos result sets
Paul Ramsey
pramsey at refractions.net
Tue Feb 24 09:15:17 PST 2004
Preferably a picture of the polygon AV says is "in" and we do not.
On Tuesday, February 24, 2004, at 08:56 AM, Paul Ramsey wrote:
> Can you give us a picture of your scenario? Asserting that ArcView is
> "right" does not aid the debugging process. Probably the issue is one
> of semantics around the OpenGIS predicates (we really need to write up
> a page of description with pictures ... )
> P.
> On Tuesday, February 24, 2004, at 08:20 AM, James S reid wrote:
>> not disjoint() is worse!! in case its my sql heres the query :
>> test=# select nuts3.* into temp from nuts2,nuts3 where not
>> disjoint(nuts3.the_geom,nuts2.the_geom) = TRUE and nuts2=2;
>> essentially Ive two tables and im tryinbg to sd a polygon in polygon
>> selection - arcview correctly brings back 8 records - the above
>> brings 15!!
>> my original with within() qurey looked like:
>> within(nuts3.the_geom,nuts2.the_geom) = TRUE and nuts2=2;
>> this brought 7 polys back - 1 less than AV and I cant figire out my it
>> dislikes it !! BTW - reversing the tables and using a contains() also
>> brings
>> back 7 polys so I think its something in the geos computation??
>> however - my SQL may be naive so if anyone can correct me Id
>> appreciate it
>> regards
>> james
>> ----- Original Message -----
>> From: "Paul Ramsey" <pramsey at refractions.net>
>> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
>> Sent: Tuesday, February 24, 2004 3:50 PM
>> Subject: Re: [postgis-users] geos result sets
>>> The definition of Within() is not what you think it is.
>>> Try using "Not Disjoint()".
>>> P.
>>> On Tuesday, February 24, 2004, at 06:59 AM, James S reid wrote:
>>>> further to my eralier queries, Ive been doing some experimenting - i
>>>> consistently get less polys that Im convinced i should using the
>>>> within() operator on 2 tables (mr ESRI agrees with me) - so either
>>>> the
>>>> geos computation is wrong, arcview is wrong or theres some subtlety
>>>> in
>>>> the precision that im missing.
>>>> has anyone else noticed weird things going on?
>>>> Postgis 0.8.0/1 pg 7.4.1 geos 1.0 cywin environment
>>>> regards
>>>> james
>>>> Edinburgh
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> Paul Ramsey
>>> Refractions Research
>>> Email: pramsey at refractions.net
>>> Phone: (250) 885-0632
> Paul Ramsey
Paul Ramsey
