[postgis-users] geos result sets
Paul Ramsey pramsey at refractions.net
Wed Feb 25 15:49:40 PST 2004
What would be the result if we were using JTS/GEOS with a precision
model more coarse than the differences between the vertices? IE, a 0.1
meter precision?
Paul Ramsey wrote:
> Thanks for the checks Martin. I think the standard that ArcView works to
> is "good enough for government work", or "plus or minus something or
> other".
> JTS/GEOS is so good it starts to beg the question -- how good is *too*
> good? :)
> Martin Davis wrote:
>> I thought I better leap to the defence of JTS/GEOS.  I've analyzed the
>> situation and (no surprise to me) found that the results from GEOS are
>> correct.  The Within=FALSE result is caused by a slight difference in
>> the vertices in the two coverages.
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
