[postgis-users] Postgis views
Tyler Mitchell TMitchell at lignum.com
Fri Feb 27 09:20:51 PST 2004
> It would be possible to put a trigger on your table that took the
> float columns
> and created a point or line geometry out of them, and updated a
> geometry column
> in your database, every time a row was inserted or updated. Then
youcould do
> all the geometric operations you want, even spatial indexing, without
really
> having to worry about the non-standard sql portion of the database
> (other than
> writing the initial trigger function).
Nice suggestion Chris! An often overlooked feature of the database.  Got
any examples handy?  I'm using views like this when I really should use a
trigger.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040227/d6268878/attachment.html>
