[postgis-users] Install PostGIS 0.8.1...postgis.sql ???
Carlos Fernando Gonçalves cgoncalves at visionweb.com.br
Fri Feb 27 17:49:12 PST 2004
Hello Greg.
If I understood well there is no problem.
Was the installation completed with success?
At once I thank his attention.
Carlos FG
> Seems quite similar to what I've seen ... the warnings are just that --
> warnings. The final "COMMIT" is the tipoff that all went well.
> Have fun!
> Greg Williamson
> DBA
> GlobeXplorer LLC
> -----Original Message-----
> From:	Carlos Fernando Gonçalves [mailto:cgoncalves at visionweb.com.br]
> Sent:	Fri 2/27/2004 5:31 PM
> To:	postgis-users at postgis.refractions.net
> Cc:
> Subject:	[postgis-users] Install PostGIS 0.8.1...postgis.sql ???
> Hello to all.
> I am using in my project Linux Red Hat 9, PostgreSQL 7.4.1 (with code
> source in tree).
> I am making the installation of the version of PostGIS 0.8.1.
> The code source where is located the directory of PostGIS is:
> /usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1
> In the file Makefiledo PostGIS, I am with the parameters
> USE_PROJ=0,USE_GEOS=0 and USE_STATS=0.
> I usually execute,
> make
> make install
> su – postgres
> createdb db_test
> createlang plpgsql db_test
> OK.
> I would like to know if it is norm in the moment of execution || psql -
> d db_test - f postgis.sql || to appear these messages:
> BEGIN
>         message
>  PL/PgSQL is installed.
> (1 row)
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:44:
> NOTICE:  type "histogram2d"
> is not yet defined
> DETAIL:  Creating a shell type definition.
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:49:
> NOTICE:  argument type histogram2d is only a shell
> CREATE FUNCTION
> CREATE TYPE
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:65:
> NOTICE:  type "box3d" is not yet defined
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:70:
> NOTICE:  argument type box3d is only a shell
> CREATE FUNCTION
> CREATE TYPE
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:85:
> NOTICE:  type "spheroid" is
> not yet defined
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:90:
> NOTICE:  argument type spheroid is only a shell
> CREATE FUNCTION
> CREATE TYPE
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:105:
> NOTICE:  type "wkb" is not
> yet defined
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:110:
> NOTICE:  argument type wkb
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:115:
> NOTICE:  return type wkb is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:124:
> NOTICE:  type "chip" is not yet defined
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:129:
> NOTICE:  argument type chip is only a shell
> CREATE FUNCTION
> CREATE TYPE
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:145:
> NOTICE:  type "geometry" is not yet defined
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:150:
> NOTICE:  argument type geometry is only a shell
> CREATE FUNCTION
> CREATE TYPE
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:260:
> NOTICE:  CREATE TABLE / PRIMARY KEY will create implicit index
> "spatial_ref_sys_pkey" for table "spatial_ref_sys"
> CREATE TABLE
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:280:
> "geometry_columns_pk" for table "geometry_columns"
> CREATE TABLE
> UPDATE 1
> UPDATE 1
> UPDATE 1
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:473:
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:478:
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:483:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:488:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:493:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:498:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:503:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:508:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:513:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:518:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:524:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:529:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:534:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:539:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:544:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:549:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:555:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:560:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:566:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:571:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:576:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:581:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:587:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:592:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:597:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:602:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:607:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:612:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:619:
> is only a shell
> CREATE FUNCTION
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:624:
> is only a shell
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE AGGREGATE
> CREATE FUNCTION
> CREATE AGGREGATE
> CREATE FUNCTION
> CREATE AGGREGATE
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE OPERATOR
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE AGGREGATE
> CREATE FUNCTION
> CREATE AGGREGATE
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE TYPE
> CREATE CAST
> CREATE CAST
> CREATE CAST
> CREATE CAST
> CREATE CAST
> CREATE CAST
> CREATE CAST
> CREATE CAST
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE OPERATOR CLASS
> UPDATE 1
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> CREATE FUNCTION
> COMMIT
> Thank you very much
> Carlos FG
> postgis-users mailing list
Carlos FG
Conheça a Região Metropolitana de São Paulo:
http://www.mapas.centrodametropole.org.br/servidormapas/html/index.html
