[postgis-users] Bugs in Postgis/GEOS
Markus Schaber
schabios at logi-track.com
Mon Jan 12 03:24:03 PST 2004
For our company project, we want to use PostGIS, but it seems that the current 0.8.0 still has some bugs that produce weird results or even lead to a PostGreSQL Server crash.
We're currently trying to isolate some simplified testcases that cause the crashes, but were not successful yet (and, as you may understand, I am not in the position to release our real world application data :-)
But for one case of weird data, I have an easy and reproducable example:
gistest=# select geom from test;
geom
SRID=-1;LINESTRING(1 1,3 3,4 4)
SRID=-1;LINESTRING(1 1,2 3,4 4)
SRID=-1;LINESTRING(1 1,2 2,4 4)
SRID=-1;LINESTRING(1 1,2 4,4 4)
(4 Zeilen)
gistest=# select geomunion(geom) from test;
geomunion
SRID=-1;MULTILINESTRING((1 1,2 4,4 4),(1 1,2 2),(2 2,3 3),(3 3,4 4),(1 1,2 3,0 0))
(1 Zeile)
geomunion
SRID=-1;MULTILINESTRING((1 1,2 4,4 4),(1 1,2 2),(2 2,3 3),(3 3,4 4),(1 1,2 3,1.7e-308 2))
(1 Zeile)
geomunion
(1 Zeile)
gistest=# select numgeometries(geom) from test;
numgeometries
Please notice that the first query produces a differen tresult compared to the following (identical) queries.
My Human brain thinks that the result should be something like
SRID=-1;MULTILINESTRING((1 1,4 4),(1 1,2 3,4 4),(1 1,2 4,4 4))
or (including some optimizations)
SRID=-1;MULTILINESTRING((1 1,4 4,2 3,1 1,2 4,4 4))
I don't see any reason for the algorithm to find coords like (0 0) or (1.7e-308 2) which are neither part of the original input data nor any intersection points thereof.
Can you reproduce this behaviour and confirm it as a bug?
What can I (with very limited C++ knowledge) do to help with fixing it?
Should I better switch to the devel list for such questions?
Thanks a lot for your patience,
Markus Schaber
PS: I'm currently developing some improvements for the PostGIS Java interface - are you interested in patches? If yes, is the devel list the correct place to discuss them?
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schabios at logi-track.com | www.logi-track.com
