[postgis-users] Intersects(geometry,geometry) fails
Greg Janée
gjanee at alexandria.ucsb.edu
Mon Jan 12 16:13:33 PST 2004
Using Intersects(geometry,geometry) fails and furthermore causes the
database connection to get hosed:
% psql spatialtest
Welcome to psql 7.4, the PostgreSQL interactive terminal.
spatialtest=# select * from main;
id | footw
1 | SRID=54001;POLYGON((0 0,2 0,7 5,2 5,0 0))
(1 row)
spatialtest=# select * from main where
spatialtest-# Intersects(footw,
spatialtest(# GeometryFromText('POLYGON((2 0,5 0,5 3,2 3,2 0))',54001));
server closed the connection unexpectedly
This probably means the server terminated abnormally
before or while processing the request.
The connection to the server was lost. Attempting reset: Failed.
I'm using PostGIS 0.8.0. Info about the spatial column in question:
spatialtest=# select * from geometry_columns;
f_table_catalog | f_table_schema | f_table_name | f_geometry_column |
coord_dimension | srid | type | attrelid | varattnum | stats
| spatialtest | main |
footw | 2 | 54001 | GEOMETRY | 125326745
| 2 |
(1 row)
Thanks,
-Greg
Greg Janée Department of Computer Science
gjanee at alexandria.ucsb.edu University of California
Santa Barbara, CA 93106-5110
805-893-8453 (voice) 805-893-3045 (fax)
