[postgis-users] Intersects(geometry,geometry) fails
David Valentine valentine at library.ucsb.edu
Tue Jan 13 15:23:12 PST 2004
Same result (on 0.8.1)
On Jan 13, 2004, at 2:17 PM, Paul Ramsey wrote:
> Could you try this "reduced" test case on your machine?
> select intersects(GeometryFromText('POLYGON((2 0,5 0,5 3,2 3,2
> 0))',54001),'SRID=54001;POLYGON((0 0,2 0,7 5,2 5,0 0))');
> We found a memory alignment problem on Solaris and fixed it, but it
> was not in the execution path for this example, so it probably did not
> fix your problem. Still, try the latest CVS of postgis and see if
> things have improved.
> Paul Ramsey wrote:
>> Well, my compile under Solaris 2.6 did not have any problems, but I
>> *am* turning up some other issues. Some of the OGC tests cause
>> segfaults, so we are onto something here.
>> More l8r.
>> P.
>> David Valentine wrote:
>>> On Jan 12, 2004, at 4:17 PM, Paul Ramsey wrote:
>>>> Werks fer me.
>>>> What GEOS version? Operating system, compiler?
>>> solaris8
>>> both GCC 2.95.3, and 3.3.2 (packages from sunfreeware.com)
>>> standard solaris tools (/usr/ccs/bin) and GNU binutils
>>> GCC3.3.2
>>> Had to use 'CFLAGS=-fPIC' to get postgis-0.80 (and 0.81) to compile
>>> Under 2.95.3 I could not get geos-1.0 to compile with
>>> LDFLAGS=-lstdc++
>       __
>      | Paul Ramsey
>      | Refractions Research
>      | Email: pramsey at refractions.net
>      | Phone: (250) 885-0632
>      \_
> postgis-users mailing list
