[postgis-users] shp2pgsql not loading in 0.8.2
strk
strk at keybit.net
Fri Jan 16 11:55:01 PST 2004
It looks like the 'oneway' column was interpreted as an integer,
I wonder if you had correct values in that column with shp2pgsql 0.8.0 ...
I made cvs version map dbf:FTLogical to pg:bool, but I do not
have data to test it on. Can you please give it a try ?
--strk;
carrolls wrote:
> Hi,
> As you can see in the output, shp2pgsql 0.8.0 worked. All output
> redirected into toload.sql. BCrte.shp is also loaded into the database
> using psql.
> Below is output from the database showing that bcrte has been imported,
> Thanks Seamus
> noschema=# \d
> List of relations
> Schema | Name | Type | Owner
> public | bcrte | table | carrolls
> public | bcrte_gid_seq | sequence | carrolls
> public | geometry_columns | table | carrolls
> public | hope | table | carrolls
> public | spatial_ref_sys | table | carrolls
> noschema=# \d bcrte
> Table "public.bcrte"
> Column | Type | Modifiers
> gid | integer | not null default nextval('public.bcrte_gid_seq'::text)
> street | character varying |
> fromleft | integer |
> toleft | integer |
> fromright | integer |
> toright | integer |
> predir | character varying |
> pretype | character varying |
> streetname | character varying |
> suftype | character varying |
> sufdir | character varying |
> carto | integer |
> left_mun | character varying |
> right_mun | character varying |
> left_maf | character varying |
> right_maf | character varying |
> left_fsa | character varying |
> right_fsa | character varying |
> left_prv | character varying |
> right_prv | character varying |
> uniqueid | integer |
> oneway | character varying |
> rte_hirchy | integer |
> road_dir | character varying |
> fromnode | integer |
> tonode | integer |
> speedmiles | integer |
> rdlenmiles | double precision |
> speedkm | integer |
> rdlenmeter | double precision |
> traveltime | double precision |
> rdlnmlselv | double precision |
> rdlnmtrelv | double precision |
> trvltimelv | double precision |
> the_geom | geometry |
> Indexes:
> "bcrte_pkey" primary key, btree (gid)
> Check constraints:
> "$1" CHECK (srid(the_geom) = -1)
> "$2" CHECK (geometrytype(the_geom) = 'MULTILINESTRING'::text OR
> the_geom IS NULL)
> On Thu, 15 Jan 2004, strk wrote:
> > carrolls wrote:
> > > Hi,
> > > I have been playing with postgis 0.8.2 and it now gives me an error when
> > > running shp2pgsql when 0.8.1 did not. I am trying to load dmti spatial
> > > data on the BC road network. I have provided outputs comparing the two
> > > versions below.
> > > carrolls at ict715b:> /scratch/postgresql-7.4/contrib/postgis-0.8.0/loader/shp2pgsql
> > > /home/vraid2/carrolls/dmti/AB_BC_MB_SK/ArcView/Nad83/CanMapRL/BC/Streets/BCrte.shp
> > > BCrte noschema > toload.sql
> > > carrolls at ict715b:> /scratch/postgresql-7.4/contrib/postgis-0.8.1/loader/shp2pgsql
> > > BCrte > toload.sql
> > > Error: field 20 has invalid or unknown field type (3)
> > Type 3 is a Logical type in dbf. I don't think it was supported before.
> > Are you ure it did actually work with previous shp2pgsql versions ?
> > > I noticed that AddGeometryColumn now allows for schemas which is great but
> > > shp2pgsql.c v1.45 0.8.2 does not appears to allow for schemas. Am I
> > > missing a simple way of loading shape files into specific schemas other
> > > than editing the created sql statements? Could an extra arguement be
> > > added to shp2pgsql for the schema and if one is not given
> > > default to the public schema?
> > The simplest way is sourcing shp2pgsql output after having set your
> > search_path starting with the schema you want the geometry tables
> > to be created. AddGeometryColumn will use current_schema() which
> > in turn will return the first schema in the comma-separated list
> > in search_path.
> > --strk;
> > > Seamus
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
