[postgis-users] undefined symbol: errstart
Matthew Haines
mhaines94108 at hotmail.com
Mon Jan 19 20:25:04 PST 2004
That did, indeed fix it. I had an older version of PostgreSQL installed. I
don't know much about RPM's, so it took a bit of trying to figure out how to
remove them. Eventually I used the GUI based Redhat tool ("Add/Remove
Applications" on the main menu). PostGIS installed nicely immediately after
that.
Hopefully I can get my maps for Queens and Da Bronx up and running tomorrow.
Matthew
>From: Paul Ramsey <pramsey at refractions.net>
>Reply-To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>Subject: Re: [postgis-users] undefined symbol: errstart
>Date: Mon, 19 Jan 2004 18:22:44 -0800
>Google is almost, but not completely, unhelpful. There is *one* reference
>to
>your error, albeit in Polish. From what I can muddle through, the response
>is
>that there is a conflict between the 7.3 and 7.4 postgresql versions.
>So... does your fresh install of RedHat 9 have some postgresql rpms sitting
>on
>it still?
>rpm -qa | grep postgres
>If there are any, remove them, so your from-source install can have the
>field
>clear to itself.
>Paul
>On January 19, 2004 05:50 pm, Matthew Haines wrote:
> > Freshly installed Redhat 9.0, installing Postgis 0.8.0 against
>PostgreSQL
> > 7.4 freshly compiled from /usr/src into /usr/local using only the
>defaults
> > and exactly according to the scripts in the docs for both programs.
> > When I execute
> > psql -d nycpr -f postgis.sql
> > I get
> > psql:postgis.sql:41: ERROR: Load of file
> > /usr/local/pgsql/lib/libpostgis.so.0.8 failed:
> > /usr/local/pgsql/lib/libpostgis.so.0.8: undefined symbol: errstart
>_______________________________________________
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
_________________________________________________________________
Find high-speed net deals comparison-shop your local providers here.
https://broadband.msn.com
