[postgis-users] Re: postgis.sql error
TECHER Jean David
davidtecher at yahoo.fr
Thu Jan 22 12:46:24 PST 2004
Hi Danny
I don't nkow if it could be a great help for you.
However you can have a glance at the script I used to install postgis 0.8.1
+ postgresql 7.4 :
http://techer.pascal.free.fr/postgis/installation_script.htm
it's french but don't matter about that. :)
In short, the versions I used are sumarized in the table
and you see the script (install.sh) after in the page.
Maybe a comparaison could be a great help.
That's all I could do.
I installed PostGIS 0.8.0 on Windows with cygwin( emulator Linux) but the
way of installation is the same
TECHER Jean David
Tél: 06-85-37-36-75
e-mail: davidtecher at yahoo.fr
Site PostGIS: http://techer.pascal.free.fr/postgis/index.htm
-----Message d'origine-----
De : postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]De la part de
postgis at dannykent.com
Envoyé : jeudi 22 janvier 2004 21:28
À : postgis-users at postgis.refractions.net
Objet : [postgis-users] Re: postgis.sql error
Thanks for the replies to my postgis.sql issue. Still looking for a
solution.
Did you put USE_GEOS=1 when you compiled postgis?
No I compiled PostGIS with USE_GEOS = 0.
Danny, could you tell us more about your setup? Did you compile
postgresql
yourself or are you using a stock version? I assume you're on some *nix
operating system. Are you sure that the postgis.sql that you are loading
is from the same version of the postgis libraries you installed?
I am installing on RH 8.0. I downloaded and installed Postgres 0.7.4.1
from the source. I am also using PostGIS 0.8. I am sure these are from the
same packages b/c this is being done on a fresh partition with nothing else
installed.
Thanks for the help, hopefully we can find the issue.
~Danny
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040122/8502c311/attachment.html>
