[postgis-users] Strange Exceptions
Markus Schaber schabios at logi-track.com
Mon Jan 26 11:21:16 PST 2004
Hi, David,
On Mon, 26 Jan 2004 10:16:57 -0800
David Blasby <dblasby at refractions.net> wrote:
> > Some strange Exceptions appeared today:
> Your query involved an intersection() that couldnt be computed.
> PostGIS is giving you more information, but Java isnt reporting it.
> Try executing the same query directly to postgresql (using psql) and
> you should see what the error message is.
Yes, I got more Information from it:
testdb=# SELECT intersection(geom,'BOX3D (6.05 46.2667,11.05
48.4667)'::box3d) FROM table WHERE geom && 'BOX3D (6.05 46.2667,11.05
48.4667)'::box3d;
HINWEIS:  TopologyException: side location conflict (6.74219,46.9513)
FEHLER:  GEOS Intersection() threw an error!
However, I currently don't really understand what it means. I guess it's
some problem with the polygon data (Polygon objects with up to 19
rings).
I'll try to investigate further.
Thanks,
Markus
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schaber at logi-track.com | www.logi-track.com
