[postgis-users] (mistake )plpgsql function for surface of multipolygon with holes
strk
strk at keybit.net
Thu Jan 29 10:50:18 PST 2004
If I remember well your problem is about holes,
so you should sum area2d(ExteriorRing(geometryN(the_geom, N)));
(you missed the ExteriorRing call)
--strk;
davidtecher wrote:
> I made a mistake :{
> -------- aire_geometrique ----------------
> DROP FUNCTION aire_geometrique(geometry);
> CREATE FUNCTION aire_geometrique(geometry) RETURNS
> real AS'
> DECLARE
> --tableau alias for $2;
> colonne_geometrique ALIAS FOR $1;
> aire real;
> aire_en_cours real;
> iter_aire integer;
> nombre_d_objects integer;
> BEGIN
> aire=0;
> iter_aire = 1;
> SELECT INTO nombre_d_objects
> numgeometries(colonne_geometrique);
> while iter_aire < (nombre_d_objects+1)
> loop
> select into aire_en_cours
> area2d(geometryn(colonne_geometrique,iter_aire));
> iter_aire = iter_aire + 1;
> aire = aire + aire_en_cours;
> end loop;
> RETURN aire;
> END;
> ' LANGUAGE 'plpgsql';
> _________________________________________________________________
> Do You Yahoo!? -- Une adresse @yahoo.fr gratuite et en français !
> Yahoo! Mail : http://fr.mail.yahoo.com
> postgis-users mailing list
