[postgis-users] Fatal: lock file file"/usr/share/postgresql/data/postmaster.pid" already exists
kenville thompson
humble_kid_99 at yahoo.com
Thu Jul 8 09:23:44 PDT 2004
Hi
My system is Windows with Cygwin.
--- TECHER Jean David <davidtecher at yahoo.fr> wrote:
> Hi
> What system do you try ??? Linux or Windows with
> Cygwin???
> TECHER JEAN DAVID
> - Responsable Informatique 01MAP -
> e-mail:davidtecher at yahoo.fr
> Tel: 06 85 37 36 75
> Site PostGIS:
> http://techer.pascal.free.fr/postgis/index.htm
> -----Message d'origine-----
> De : postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]De
> la part de
> kenville thompson
> Envoye : mercredi 7 juillet 2004 22:53
> A : postgis-users at postgis.refractions.net
> Objet : [postgis-users] Fatal: lock file
> already exists
> I am having a problem intitalizing the postgresql
> database.
> Could please send any suggestion that you may have,
> so
> i can move on to installing GT3.Thank you.
> This is my error:
> $ initdb -D /usr/share/postgresql/data
> The files belonging to this database system will be
> owned by user "Thompson".
> This user must also own the server process.
> The database cluster will be initialized with locale
> C.
> creating directory /usr/share/postgresql/data... ok
> creating directory
> /usr/share/postgresql/data/base...
> ok
> creating directory
> /usr/share/postgresql/data/global... ok
> creating directory
> /usr/share/postgresql/data/pg_xlog... ok
> creating directory
> /usr/share/postgresql/data/pg_clog... ok
> selecting default max_connections... Signal 12
> Signal 12
> Signal 12
> Signal 12
> Signal 12
> Signal 12
> 10
> selecting default shared_buffers... Signal 12
> Signal 12
> Signal 12
> Signal 12
> Signal 12
> Signal 12
> Signal 12
> Signal 12
> Signal 12
> Signal 12
> Signal 12
> 50
> creating configuration files... ok
> creating template1 database in
> /usr/share/postgresql/data/base/1... FATAL: lock
> file "/usr/share/postgresql/data/postmaster.pid"
> already exists
> HINT: Is another postgres (PID 1848) running in
> data
> directory "/usr/share/post
> gresql/data"?
> initdb: failed
> initdb: removing data directory
> "/usr/share/postgresql/data"
> __________________________________
> Do you Yahoo!?
> Yahoo! Mail - 50x more storage than other providers!
> http://promotions.yahoo.com/new_mail
> postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
Do you Yahoo!?
Yahoo! Mail is new and improved - Check it out!
