[postgis-users] Loading Large Datasets
Randy Page
randy.page at terraverge.com
Fri Jul 9 06:09:34 PDT 2004
Hi All,
I'm relatively new to PostGIS, but have a lot of experience with ArcSDE.
I'm getting ready to load the entire national set of Tiger data (roads,
tracts, block groups, etc.) into PostGIS. I have a tool that allows me to
generate shape files either for the entire country or an entire state, so I
can either build a single large shape file for each feature, or start out
with smaller ones and append them to create a seamless coverage in PostGIS.
My goal is to have a single dataset for each feature type. So, I have a
few questions for those of you who have experience loading large datasets.
1) Are there any issues with loading a single large dataset such as
national coverage of roads (the SQL file is nearly 3GB?) Is it preferable
to load the data in smaller batches maybe by state?
2) I have been running a few tests, and have had no problems loading a few
individual counties. However, I did try loading the entire national set of
streets using shp2pgsql and ran across a few problems while executing the
sql statement. I found that about 1 in 3 blocks produced an error similar
to this:
NOTICE: current transaction is aborted, queries ignored until end of
transaction block
I checked the sql statement, and it's using varchar for each data field, so
I don't think there is an issue with data types. Any ideas?
Thanks in advance,
Randy
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040709/f196a687/attachment.html>
