[postgis-users] Very long time for a bbox/within query
Paul Ramsey
pramsey at refractions.net
Tue Jul 20 14:58:57 PDT 2004
I think I like this construction better...
select v_boundary.v_bndry_id, count(*)
from parcels,v_boundary
where
v_boundary.the_geom && parcels.the_geom
and
within(v_boundary.the_geom,parcels.the_geom)
and
v_bndry_type = 'FIPS'
group by v_boundary.v_bndry_id;
Gregory S. Williamson wrote:
> Dear peoples,
> I have a query which is taking a while to complete and I am wondering if I have missed some obvious thing.
> We have a lot of vector data in various tables (statistics, roads, flood plains, parcel data, etc.). We need to be able to know at runtime which types of data for a given geographic area (currently a county, or FIPs code but this might be a zip or MSA in other applications). So, I thought, lets build a cross-reference table with an entry for each table/area which has data.
> Works well for most of the tables (lines, points and polygons), taking a few minutes to cross reference the 5000+ FIPS for each target table. Alas, though, we have a modest size table (parcels, about 4.1 million rows) which takes so long to run that i was convinced I had a bug. Eventually was patient enough to let it run and lo! and behold! it does work, but slowly.
> Any suggestions would be most welcome !
> This is the current query:
> SELECT 1 FROM parcels WHERE the_geom && (SELECT box3d((SELECT v_bndry_geometry FROM v_boundry WHERE v_bndry_type = 'FIPS' AND v_bndry_id =
> '12009')))::box3d AND within(the_geom, (SELECT v_bndry_geometry FROM v_boundry WHERE v_bndry_type = 'FIPS' AND v_bndry_id = '12009'));
> And this is what explain analyze says:
> Index Scan using parcels_s_ndx on parcels (cost=154.24..198.39 rows=7 width=0)
> (actual time=118806.770..118806.770 rows=0 loops=1)
> Index Cond: (the_geom && ($1)::geometry)
> Filter: within(the_geom, $2)
> InitPlan
> -> Result (cost=77.11..77.13 rows=1 width=0) (actual time=9.209..9.261 rows=1 loops=1)
> InitPlan
> -> Seq Scan on v_boundry (cost=0.00..77.11 rows=2 width=32) (actual time=5.670..6.327 rows=1 loops=1)
> Filter: (((v_bndry_type)::text = 'FIPS'::text) AND ((v_bndry_id)::text = '12009'::text))
> 5.403..6.063 rows=1 loops=1)
> Total runtime: 118807.170 ms
> (11 rows)
> The parcels table looks like this:
> gex_vector=# \d parcels
> Table "public.parcels"
> Column | Type | Modifiers
> gid | integer | not null default nextval('public.parcels_g
> id_seq'::text)
> s_pin | character varying |
> s_id | character varying |
> s_parent_p | character varying |
> s_state | character varying |
> s_city | character varying |
> s_zip | character varying |
> s_zip_plus | character varying |
> s_house | character varying |
> s_house2 | character varying |
> s_fraction | character varying |
> s_directio | character varying |
> s_street | character varying |
> s_suffix | character varying |
> s_post_dir | character varying |
> s_unit | character varying |
> s_unit_des | character varying |
> s_r_type | character varying |
> s_r_number | character varying |
> s_box_numb | character varying |
> s_fips_cou | character varying |
> the_geom | geometry |
> track_id | integer |
> ownername | character varying |
> owneraddre | character varying |
> owneraddre__21 | character varying |
> owneraddre__22 | character varying |
> ownercity | character varying |
> ownerstate | character varying |
> ownerzip | integer |
> ownerzip4 | character varying |
> the_cntr | geometry |
> Indexes:
> "parcels_pkey" primary key, btree (gid)
> "parcel_cent_ndx" gist (the_cntr)
> "parcels_ownername_ndx" btree (ownername)
> "parcels_s_fips_cou" btree (s_fips_cou)
> "parcels_s_house_ndx" btree (s_house)
> "parcels_s_ndx" gist (the_geom)
> "parcels_s_pin_ndx" btree (s_pin)
> "parcels_s_street_ndx" btree (s_street)
> Check constraints:
> "$1" CHECK (srid(the_geom) = 4326)
> "$2" CHECK (geometrytype(the_geom) = 'MULTIPOLYGON'::text OR the_geom IS NULL)
> Foreign-key constraints:
> "trackid_fk" FOREIGN KEY (track_id) REFERENCES v_detail(track_id)
> [overindexed I think but this isn't "mine" in design]
> And the boundry table is:
> v_bndry_type | character varying(20) | not null
> v_bndry_id | character varying(100) | not null
> v_bndry_ref_id | integer | not null default nextval('public.v_boundry_v_bndry_ref_id_seq'::text)
> v_bndry_geometry | geometry |
> Indexes:
> "v_boundry_pkey" primary key, btree (v_bndry_ref_id)
> Check constraints:
> "$2" CHECK (srid(v_bndry_geometry) = -1)
> "$1" FOREIGN KEY (v_bndry_type) REFERENCES v_bndry_types(v_bndry_t_code)
> Thanks for your time !
> Greg Williamson
> DBA
> GlobeXplorer LLC
> postgis-users mailing list
