[postgis-users] Still installation (last step) problems
strk strk at keybit.net
Thu Jul 22 00:16:27 PDT 2004
On Wed, Jul 21, 2004 at 09:06:12PM -0700, Bato Pure wrote:
> Hi,
> Thanks Techer Jean David, strk and Darren H.
> Current situation after giving "psql -d mydb -f
> postgis.sql":
> BEGIN
>         message
>  PL/PgSQL is installed.
> (1 row)
> psql:postgis.sql:38: NOTICE:  type "histogram2d" is
> not yet defined
> DETAIL:  Creating a shell type definition.
> CREATE FUNCTION
> psql:postgis.sql:43: NOTICE:  argument type
> histogram2d is only a shell
> CREATE FUNCTION
> CREATE TYPE
> psql:postgis.sql:59: NOTICE:  type "box3d" is not yet
> defined
> CREATE FUNCTION
> psql:postgis.sql:64: NOTICE:  argument type box3d is
> only a shell
> CREATE FUNCTION
> CREATE TYPE
> psql:postgis.sql:79: NOTICE:  type "spheroid" is not
> yet defined
> CREATE FUNCTION
> psql:postgis.sql:84: NOTICE:  argument type spheroid
> is only a shell
> CREATE FUNCTION
> CREATE TYPE
> psql:postgis.sql:99: NOTICE:  type "wkb" is not yet
> defined
> CREATE FUNCTION
> psql:postgis.sql:104: NOTICE:  argument type wkb is
> only a shell
> CREATE FUNCTION
> psql:postgis.sql:109: NOTICE:  return type wkb is only
> a shell
> CREATE FUNCTION
> psql:postgis.sql:118: NOTICE:  type "chip" is not yet
> defined
> CREATE FUNCTION
> psql:postgis.sql:123: NOTICE:  argument type chip is
> only a shell
> CREATE FUNCTION
> CREATE TYPE
> psql:postgis.sql:139: NOTICE:  type "geometry" is not
> yet defined
> CREATE FUNCTION
> psql:postgis.sql:144: NOTICE:  argument type geometry
> is only a shell
> CREATE FUNCTION
> CREATE TYPE
> CREATE FUNCTION
> psql:postgis.sql:179: NOTICE:  CREATE TABLE / PRIMARY
> KEY will create implicit index "spatial_ref_sys_pkey"
> for table "spatial_ref_sys"
> CREATE TABLE
> psql:postgis.sql:201: NOTICE:  CREATE TABLE / PRIMARY
> KEY will create implicit index "geometry_columns_pk"
> for table "geometry_columns"
> CREATE TABLE
> UPDATE 1
> ...(few lines without errors)
> psql:postgis.sql:444: NOTICE:  return type wkb is only
> a shell
> CREATE FUNCTION
> psql:postgis.sql:449: NOTICE:  return type wkb is only
> a shell
> CREATE FUNCTION
> psql:postgis.sql:454: NOTICE:  argument type wkb is
> only a shell
> CREATE FUNCTION
> ... (repeating the line)
> ... (few lines without errors)
> CREATE FUNCTION
> COMMIT
> ______________________________________________________
> What I did is:
> - reinstalled proj4 with its default location
> - reinstalled postgis
> - dropped mydb and recreated it
> - /usr/local/lib was added to /etc/ld.so.conf as
> before
> OS: Redhat 9
> Postgres: 7.4.3
> Any more help?
> Bato
You have successfully installed postgis. Congratulations ;)
The 'errors' are not ERRORs, but NOTICEs...
--strk;
