[postgis-users] Bug in centroid() ?
Pierrick Brihaye pierrick.brihaye at culture.gouv.fr
Thu Jul 22 02:04:00 PDT 2004
Given the following data structure :
CREATE TABLE test_table(
   gid serial NOT NULL,
   the_geom public.geometry
) WITH OIDS;
INSERT INTO test_table (the_geom)
   VALUES (GeometryFromText('POINT(149149 -2344411)',-1));
The following statement :
SELECT postgis_version(), envelope(the_geom), centroid(the_geom),
centroid(envelope(the_geom)) FROM test_table;
Returns (reformated as rows) :
"0.8 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
"SRID=-1;POLYGON((149149 -2344411,149149 -2344411,149149 -2344411,149149
-2344411,149149 -2344411))"
"SRID=-1;POINT(149149 -2344411)"
"SRID=-1;POINT(-1.#IND -1.#IND)"
First of all, could postgis_version() be more verbose and, for example,
display the GEOS and the PROJ version ? It would help in debugging,
wouldn't it ?
Second, my PostGIS version is old and maybe my problem is already fixed.
Is so, please forgive me. I didn't see anything about this topic in the
PostGIS and GEOS CVS logs though...
As you can see, the centroid(envelope(the_geom)) can't return a valid
result. OK, I admit that this indirection is quite odd, but is should
return that same result as centroid(the_geom), shouldn't it ?
Whose fault is it ? GEOS's or PostGIS's ?
Cheers,
Pierrick Brihaye, informaticien
Service régional de l'Inventaire
DRAC Bretagne
mailto:pierrick.brihaye at culture.gouv.fr
+33 (0)2 99 29 67 78
