[postgis-users] Fwd: Re: problems running postgis.sql
odain2 at mindspring.com
Sun Jul 25 16:56:01 PDT 2004
You were right. I was having trouble loading data, but that was because I'd
give the table a mixed-case name, not because of problems with postgis.sql.
It works great now, Thanks!
Date: Sun, 25 Jul 2004 13:40:07 -0700
From: "Gregory S. Williamson" <gsw at globexplorer.com>
Subject: RE: [postgis-users] problems running postgis.sql
To: "PostGIS Users Discussion"
<postgis-users at postgis.refractions.net>,
Message-ID:
<71E37EF6B7DCC1499CEA0316A256832801057CE3 at loki.wc.globexplorer.net>
Content-Type: text/plain; charset="Windows-1252"
Oliver --
The messages in the message below seem to be normal warnings from the postGIS
definition. If there was nothing other than "NOTICE..." messages I would
guess that you installed the postGIS module successfully. Try running the sql
to define the "spatial_ref_sys.sql" (part of the postGIS module) ... if that
suceeds then you did indeed create postGIS successfully. If not, post back to
the list with the rest of the output from the original install and from the
failed attempt at making the spatial reference system entries.
HTH,
Greg Williamson
DBA
GlobeXplorer LLC
