[postgis-users] GIST index statistics
David Blasby dblasby at gmail.com
Wed Jul 28 12:00:07 PDT 2004
Did you compile with USE_STATS=1 and then do a
select UPDATE_GEOMETRY_STATS();
This will turn on the statistical analysis that usually makes the
query planner more rational.
dave
ps. make sure geometry_columns has the proper entries in it.
On Wed, 28 Jul 2004 11:37:09 -0700, ken <southerland at samsixedd.com> wrote:
> I just recently starting looking at postgis due to a failure in the
> rtree indices of postgres to handle my situation.  Unfortunately, and I
> guess not surprisingly since GIST indices are built on postgres's rtree
> index, I experience the same problem with postgis.
> I have the following table ...
> test=# \d gistest
>           Table "public.gistest"
>    Column    |       Type       | Modifiers
> fid1         | numeric(64,0)    | not null
> fid2         | numeric(64,0)    | not null
> diagonalsize | double precision |
> geometry     | geometry         |
> Indexes:
>    "gistest_diagonalsize_idx" btree (diagonalsize)
>    "gistest_geometry_idx" gist (geometry)
> Check constraints:
>    "$1" CHECK (srid(geometry) = -1)
>    "$2" CHECK (geometrytype(geometry) = 'POLYGON'::text OR geometry IS
> NULL)
> .... and it has 2898640 rows in it.  If I try the following query ...
> explain analyze SELECT *
> FROM gistest
> WHERE geometry && GeometryFromText('BOX3D(825160.2564102565
> 685833.3333333333, 134839.74358974356 264166.6666666666)', -1 )
> AND diagonalSize > 7638.888888888889;
> .... I get the following query plan ...
>        QUERY PLAN
> Index Scan using gistest_geometry_idx on gistest  (cost=0.00..60.20
> rows=1 width=278)
>   Index Cond: (geometry && 'SRID=-1;BOX3D(134839.743589744
> 264166.666666667 0,825160.256410256 685833.333333333 0)'::geometry)
>   Filter: ((diagonalsize > 7638.88888888889::double precision) AND
> (geometry && 'SRID=-1;BOX3D(134839.743589744 264166.666666667
> 0,825160.256410256 685833.333333333 0)'::geometry))
> (3 rows)
> .... despite the fact that condition on the geometry alone returns
> 2896058 rows or almost the entire table!  The statistics, despite a
> vacuum analyze on the table, suggest that only 1 row will be returned!
> The diagonalsize condition alone returns only 2490 rows and therefore
> the query plan should use the index on this diagonalsize with a filter
> based on the overlaps condition.  Yet due to the completely incorrect
> statistics on the geometry column it doesn't.
> Any ideas?
> Ken
> postgis-users mailing list
