[postgis-users] Very slow with geometries having thousands of points
strk
strk at keybit.net
Fri Jul 30 05:27:54 PDT 2004
Tuan, take a look at WKB output functions, they would speed up things.
Also consider using a binary cursor.
--strk;
On Fri, Jul 30, 2004 at 07:14:44PM +0700, Tuan Pham Anh wrote:
> Hello PostGIS users,
> I'm new to PostGIS and this is my first problem, and I hope you can help
> me.
> I have a geo table in PostgreSQL with 8 records, but each record
> contains some polygons with thousands of points.
> So in my test application in Java, I do the following code :
> String _strDriver = "org.postgresql.Driver";
> String _strDatabaseURL = "jdbc:postgresql://localhost:5432/mydb";
> String _strUserName = "tuanpa";
> String _strPassword = "";
> String _strSQL = "select geom from tbl_regions";
> Class.forName(_strDriver);
> Connection conn = DriverManager.getConnection(_strDatabaseURL,
> _strUserName, _strPassword);
> Statement s = conn.createStatement();
> ResultSet r = s.executeQuery(_strSQL);
> while (r.next()) {
> // Do nothing here.
> r.close();
> s.close();
> conn.close();
> OK, it's quite simple.
> So my question are:
> 1. I don't know why it take too much resources. In my computer, Celeron
> 1.7, 512 MB RAM, It takes 4 seconds and 100% process.
> I use Window XP, PostgreSQL version 7.4.
> 2. I have read somewhere said that PostgreSQL doesn't get good
> performance on Window box. So I love to hear how the performance is on
> Linux box.
> I have upload the scripts to create table and insert data at:
> http://www.vngeobiz.com/temp/script.zip
> Thanks,
> Pham Anh Tuan
> R&D Officer
> Geobiz - GIS Technology Solutions.
> Website: http://www.vngeobiz.com/
> Email: tuanpa at vngeobiz.com
> postgis-users mailing list
