[postgis-users] usage of AddGeometryColumn etc.
strk
strk at keybit.net
Thu Jun 3 08:14:22 PDT 2004
On Thu, Jun 03, 2004 at 04:42:53PM +0200, Markus Schaber wrote:
> Hi,
> On Thu, 3 Jun 2004 00:01:05 +0200
> strk <strk at keybit.net> wrote:
> > FYI, Cleanup will currently (CVS) be done by:
> > AddGeometryColumn()
> > fix_geometry_columns()
> > update_geometry_stats()
> > These functions will remove stale records.
> Great!
> Do they emit a info / warning when such records were found?
fix_geometry_columns(), update_geometry_stats() and
update_goemetry_stats(table, geomcolumn) will print a short
report of their activity.
AddGeometryColumn(...) will 'eat' output of fix_geometry_columns()
and eventual deletion of a pre-existing interfeering record.
WARNING: malformed records in geometry_columns will be deleted!
This are records for which f_table_schema is the incorrect
schema. Since unexistant or empty or null schemas in
f_table_schema will be tranformed to 'public' these might
also end up getting the incorrect value.
--strk;
> Thanks,
> markus
> markus schaber | dipl. informatiker
> logi-track ag | rennweg 14-16 | ch 8001 zürich
> phone +41-43-888 62 52 | fax +41-43-888 62 53
> mailto:schabios at logi-track.com | www.logi-track.com
> postgis-users mailing list
