WG: [postgis-users] very Poor Performance for Contains
David Blasby dblasby at refractions.net
Tue Jun 8 09:26:05 PDT 2004
The reason why contains() is so slow is because it starts from scratch
every test.  It doesnt save any of the information about the geometry
objects, so it has to compute them every time you run contains().
Second, its using extended math routines so that it will ALWAYS return
the correct result.
Third, doing a contains() on a complex polygon is a lot of work!
The slow query is probably because the PostGIS->WKB->bytea->Output Text
is not highly optimized.  You can try lwgeom and see if its faster for you.
dave
