[postgis-users] polygon/multipolygon limitation?
Hubert Fröhlich
hubert.froehlich at bvv.bayern.de
Wed Jun 9 06:42:26 PDT 2004
Hello list,
Application: I have ca. 100000 polygons ( a neighborhood of land
register parcels) and want to get the outer boundary of the area
enclosing all polygons exactly.
PostGIS could do this by applying several successive operations of
GeomUnion(geometry, geometry) in a loop (n=100000) . It is clear that I
will get huge polygons (with several 1000 vertices).
My trials so far have not been very successful: High disk I/O load
leading even sometimes to postgres errors like
"invalid page header in block ..."
and, therefore, VERY strange results
My question now:
- Is there a way for PostGIS to process this task?
- I am looking for a better way than the one I originally proposed.
- The way I proposed seems to produce too much load. How to reduce it?
- Is there a limitation on vertices in polygons etc. turning my
application into crash?
Regards,
Hubert
Dr.-Ing. Hubert Fröhlich
Bezirksfinanzdirektion München
Alexandrastr. 3, D-80538 München, GERMANY
Tel. :+49 (0)89 / 2190 - 2980
Fax :+49 (0)89 / 2190 - 2997
hubert dot froehlich at bvv dot bayern dot de
