[postgis-users] Error in some reference systems in the table SPATIAL_REF_SYS
Frank Warmerdam
warmerdam at pobox.com
Mon Jun 14 06:23:27 PDT 2004
strk wrote:
> Latest SPATIAL_REF_SYS (1.7) *has* prime meridian specifications (at least
> for Gauss-Boaga...) while revision 1.5 *did not* have them.
> Prime meridians have been introduced on 2003-02-03.
> Should they be removed again to work against proj 4.4.8 ?
Strk,
Does the SPATIAL_REF_SYS definition (in PROJ.4 format) match the one in the
epsg file distributed with proj 4.4.8? There were previous releases that
included the +pm option but that didn't work properly in a couple different
ways. In particular, there were issues with the central meridian in the
translated file in combination with some issue with the +pm flag. In
combination the bugs cancelled themselves out in some early versions of
PROJ.4 with +pm support but to use PROJ.4 you have to ensure you get the
new PROJ 4.4.8 definition of the coordinate system.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
