[postgis-users] Optimizer guess makes query 1000x slower?
rm_postgis at cheapcomplexdevices.com
Tue Jun 15 03:36:45 PDT 2004
On Tue, 15 Jun 2004, strk wrote:
> Report explain analyze select ... results if you want more help.
> Also try modifying the query. The selectivity estimator only works
> in the presence of a constant geometry in one side of the && operator.
I have explain analyze results here. Table definitions "\d tablename"
follow the "explain analyze select" results". The line that makes me think
it's a bad optimizer guess is the "rows=" part of this line:
"Nested Loop (cost=0.00..218.01 rows=1 width=546) (actual
time=2555.501..202056.918 rows=6357 loops=1)"
Ron
[explain analyze results follow]
ronmap=# set enable_nestloop = true;
SET
ronmap=# explain analyze
SELECT *
FROM cpal_events,cpal_selected_events
WHERE cpal_events.nextval=cpal_selected_events.eventid
and cpal_selected_events.owner='user.23469878.20252'
and the_geom && setSRID( 'BOX3D(-121.586865184167 38.4277618656666,-121.336132412548 38.6954249341005)'::BOX3D,find_srid('','cpal_events','the_geom'));
QUERY PLAN
Nested Loop (cost=0.00..218.01 rows=1 width=546) (actual time=2555.501..202056.918 rows=6357 loops=1)
Join Filter: ("outer".nextval = "inner".eventid)
-> Index Scan using cpal_event_summary__gist on cpal_events (cost=0.00..6.01 rows=1 width=503) (actual time=0.100..261.886 rows=9570 loops=1)
Index Cond: (the_geom && 'SRID=-1;BOX3D(-121.586865184167 38.4277618656666 0,-121.336132412548 38.6954249341005 0)'::geometry)
-> Seq Scan on cpal_selected_events (cost=0.00..132.50 rows=6360 width=43) (actual time=0.005..12.020 rows=6357 loops=9570)
Filter: ("owner" = 'user.23469878.20252'::text)
Total runtime: 202079.387 ms
(7 rows)
ronmap=# set enable_nestloop = false;
SET
SELECT *
QUERY PLAN
Merge Join (cost=540.31..572.13 rows=1 width=546) (actual time=161.258..266.926 rows=6357 loops=1)
Merge Cond: ("outer".nextval = "inner".eventid)
-> Sort (cost=6.02..6.03 rows=1 width=503) (actual time=129.153..137.399 rows=9570 loops=1)
Sort Key: cpal_events.nextval
-> Index Scan using cpal_event_summary__gist on cpal_events (cost=0.00..6.01 rows=1 width=503) (actual time=0.103..78.088 rows=9570 loops=1)
-> Sort (cost=534.29..550.19 rows=6360 width=43) (actual time=32.047..37.490 rows=6357 loops=1)
Sort Key: cpal_selected_events.eventid
-> Seq Scan on cpal_selected_events (cost=0.00..132.50 rows=6360 width=43) (actual time=0.074..15.649 rows=6357 loops=1)
Total runtime: 281.134 ms
(11 rows)
ronmap=# \d cpal_events;
Table "public.cpal_events"
Column | Type | Modifiers
nextval | bigint |
the_geom | geometry |
[and lots of columns of data]
Indexes:
"cpal_events__oid" unique, btree (oid)
"cpal_event_summary__gist" gist (the_geom)
"cpal_events__gist" gist (the_geom)
Check constraints:
"$2" CHECK (geometrytype(the_geom) = 'POINT'::text OR the_geom IS NULL)
"$1" CHECK (srid(the_geom) = -1)
ronmap=#
ronmap=# \d cpal_selected_events;
Table "public.cpal_selected_events"
name | text |
owner | text |
eventid | integer |
