[postgis-users] Using/Compiling PostGIS on Windows XP/Cygwin for use with PostgreSQL
Chapman, Martin MChapman at sanz.com
Fri Jun 25 16:01:14 PDT 2004
You need to download and install proj4.  It's the projection library
used by postgis to handle projecting lat/lons into x,y and the inverse.
The zip can be found at http://www.remotesensing.org:16080/proj/ .
Follow the build instructions for windows using the vc compiler.  Let me
know if you have problems.  You also need geos which can be found at
http://geos.refractions.net .
Martin Chapman
-----Original Message-----
From: Rudolf Nottrott [mailto:rnott at alexandria.UCSB.edu]
Sent: Friday, June 25, 2004 4:56 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Using/Compiling PostGIS on Windows XP/Cygwin
Hello,
I have been using PostGIS 7.4.3.1,  running under Cygwin on Windows XP,
and
that works fine.
Now I want to add  PostGIS, but during the installation I get
compilation
errors, as outlined below.
Has anybody done this, I mean successfully installed and used PostGIS
with
PostgreSQL on Windows XP?
Would you please give me some advice here?
Thanks for your help and support.
Rudolf
DESCRIPTION OF THE PROCEDURE THAT RESULTS IN ERROR "projects.h: No such
file or directory":
So to install PostGIS with PostgreSQL on Windows XP/Cygwin I followed
the
instructions at
http://www.gasai.com/gisapps/WindowsHowTo.html#Set%20up%20PostGIS
section "Set up PostGIS",  which includes
- getting postgis-0.8.1.tar.gz
- putting it into the PostgreSQL contrib directory
     usr/src/postgresql-7.4.3-1/contrib
- untaring/unzipping it there, which results in a directory
     usr/src/postgresql-7.4.3-1/contrib/postgis-0.8.1    and
- running
     'make' in
- When I run that last 'make', I get an error about missing
   projects.h, as follows
$ make
gcc -O2 -fno-strict-aliasing -Wall -Wmissing-prototypes
-Wmissing-declarations -g -fexceptions   -I. -DFRONTEND
-DSYSCONFDIR='"/etc/postgresql"'  -DUSE_VERSION=74
-I/usr/local/include/geos -DUSE_GEOS -I/usr/local/include
-DUSE_PROJ  -DUSE_STATS  -I../../src/include   -c -o postgis_transform.o
postgis_transform.c
postgis_transform.c:52:22: projects.h: No such file or directory
postgis_transform.c:55: error: syntax error before '*' token
postgis_transform.c:55: warning: type defaults to `int' in declaration
of
`make_project'
postgis_transform.c:55: warning: data definition has no type or storage
class
postgis_transform.c:59: error: syntax error before '*' token
postgis_transform.c:64: error: syntax error before '*' token
postgis_transform.c:67: warning: no previous prototype for
`pj_transform_nodatum'
etc., etc.
In an attempt to install PostGIS into my existing PostGIS 7.4.3.1, I
followed the instructions at
which include
Rudolf
Santa Barbara
Rudolf Nottrott
University of California Santa Barbara     Phone: (805) 893-6146
Department of Computer Science           E-mail:
RNott at Alexandria.UCSB.edu
Alexandria Digital
Library                       Web:    www.alexandria.ucsb.edu
Santa Barbara, California  93106
postgis-users mailing list postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
