[postgis-users] Using/Compiling PostGIS on Windows XP/Cygwin for use with PostgreSQL
Rudolf Nottrott
rnott at alexandria.UCSB.edu
Fri Jun 25 16:19:43 PDT 2004
Sorry for my ignorance with this, but I know nothing about PostgreSQL
"native" window builds. Would those be PostgreSQL packages precompiled for
Windows (something like PostSQL *.dll), in other words PostgreSQL WIndows
binary packages, DLLs?
Do those come with PostGIS and other contrib modules, or how are new
modules added to those?
Thanks,
Rudolf
At 04:09 PM 6/25/2004 -0700, you wrote:
>You might consider also trying the native windows build. I haven't used
>it on XP but have had great success on 2000.
>There are precompiled packages available through folks on this list.
>Tyler
>postgis-users-bounces at postgis.refractions.net wrote on 06/25/2004 03:56:28
>PM:
> > Hello,
> > I have been using PostGIS 7.4.3.1, running under Cygwin on Windows XP,
>and
> > that works fine.
> > Now I want to add PostGIS, but during the installation I get
>compilation
> > errors, as outlined below.
> > Has anybody done this, I mean successfully installed and used PostGIS
>with
> > PostgreSQL on Windows XP?
> > Would you please give me some advice here?
> > Thanks for your help and support.
> > Rudolf
> > DESCRIPTION OF THE PROCEDURE THAT RESULTS IN ERROR "projects.h: No such
> > file or directory":
> > So to install PostGIS with PostgreSQL on Windows XP/Cygwin I followed
>the
> > instructions at
> > http://www.gasai.com/gisapps/WindowsHowTo.html#Set%20up%20PostGIS
> > section "Set up PostGIS", which includes
> > - getting postgis-0.8.1.tar.gz
> > - putting it into the PostgreSQL contrib directory
> > usr/src/postgresql-7.4.3-1/contrib
> > - untaring/unzipping it there, which results in a directory
> > usr/src/postgresql-7.4.3-1/contrib/postgis-0.8.1 and
> > - running
> > 'make' in
> > - When I run that last 'make', I get an error about missing
> > projects.h, as follows
> > $ make
> > gcc -O2 -fno-strict-aliasing -Wall -Wmissing-prototypes
> > -Wmissing-declarations -g -fexceptions -I. -DFRONTEND
> > -DSYSCONFDIR='"/etc/postgresql"' -DUSE_VERSION=74
> > -I/usr/local/include/geos -DUSE_GEOS -I/usr/local/include
> > -DUSE_PROJ -DUSE_STATS -I../../src/include -c -o postgis_transform.o
> > postgis_transform.c
> > postgis_transform.c:52:22: projects.h: No such file or directory
> > postgis_transform.c:55: error: syntax error before '*' token
> > postgis_transform.c:55: warning: type defaults to `int' in declaration
>of
> > `make_project'
> > postgis_transform.c:55: warning: data definition has no type or storage
>class
> > postgis_transform.c:59: error: syntax error before '*' token
> > postgis_transform.c:64: error: syntax error before '*' token
> > postgis_transform.c:67: warning: no previous prototype for
> > `pj_transform_nodatum'
> > etc., etc.
> > In an attempt to install PostGIS into my existing PostGIS 7.4.3.1, I
> > followed the instructions at
> > which include
> > Rudolf
> > Santa Barbara
> > Rudolf Nottrott
> > University of California Santa Barbara Phone: (805) 893-6146
> > Department of Computer Science E-mail:
>RNott at Alexandria.UCSB.edu
> > Alexandria Digital
> > Library Web: www.alexandria.ucsb.edu
> > Santa Barbara, California 93106
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
