[postgis-users] Using/Compiling PostGIS on Windows XP/Cygwin for use with PostgreSQL
Tyler Mitchell
tjmitchell at riverside.bc.ca
Fri Jun 25 16:30:45 PDT 2004
> Are you saying that proj4 and geos are required to run
> PostGIS with PostgreSQL on Windows/Cygwin?
They were set to "1" in your Makefile so in that sense, yes, they are
required. But you can disable them if you don't want or need them yet.
> Are they also required to run PostGIS with PostgreSQL on other
platforms,
> in particular Linux?
No. Not required anywhere.
> If so, that adds up to quite an installation chore, mostly because of
the
> potential errors that can occur.
> I feel a bit daunted!
Don't feel that way - it's an option.
